Eucalyptus splitter.
/ Eucalyptus splitter.
Your pump size is way too big and will result in a 13 ton max output. If you use a 13GPM pump, you'll get 30 tons of force.
My math should be verified by an expert, lol.
Edit: Guess you can get two stage pumps that give the speed/force combination you are looking for.
http://www.ebay.com/itm/28-GPM-2-STAGE-HYDRAULIC-LOG-SPLITTER-PUMP-ToolTuff-Hydraulics-Wood-Splitter-/271303389853#ht_382wt_1126
What was that limiting factor you came up with?
Here is what I was thinking.
http://www.surpluscenter.com/Hydrau...-Pumps/28-GPM-DYNAMIC-2-STAGE-PUMP-9-7971.axd
Doing some calculations of a cylinder with a 5" bore running @ 3000psi.... I only come up with 29 tons of force. I was hoping to do more for this build. I have been trying to source a cylinder with a 5.5" or 6" bore at a reasonable price but have come up short.
/ Eucalyptus splitter. #24
I'm new to log splitters, so didn't know that they use a "two stage" pump. The high capacity stage pumps until resistance is met, and then it automatically shifts to the smaller stage. The smaller the gpm of the pump for a given motor HP and cylinder bore size, the higher the force exerted. If you 28 GPM pump is actually a two stage with a 20 gpm and 8 gpm per say, then the smaller gpm would give you the force you want.
Correct!
/ Eucalyptus splitter. #26
28 GPM DYNAMIC 2-STAGE PUMP
The pressure exerted at engine stall on the 7gpm pump would be almost 5400 psi without a relief valve. Since it's pressure is rated at 3000 psi max, then max force exerted would be 29 tons as you stated. Guess you would need a bigger diameter ram to get more force, or a higher pressure rated pump/system.
As a reference, there is a log splitter on northern tool that exerts "37 tons", and it has a 5" ram, but 3500 psi max pressure setting. In the specs, it lists continuous force as 34.3 tons. You would need 3770psi to get real 37 tons.
Sorry for the thread jack, you are helping me build my log splitter also.
As for your original post, I would guess that the hedge apple trees in the midwest would most closely resemble the "springiness" of the eucalyptus tree.
5" x 24" looks to be the biggest I want to go for the money. A 6" x 24" is more than double.
Well the search it continuing. I found a 6"x25' ram at a recycling center/ junkyard. Got it for scrap price…. $45 :drink: Seams to be in decent shape.
/ Eucalyptus splitter. #29
I'm sure you meant 25", lol. That would be a real tree splitter otherwise. Sounds like you are well on your way to an industrial stregth splitter.
You are splitting redgum for firewood?? Have you no soul?
Alan
hahahaha:laughing: I must be sacred tree for you OZ folks! For us in SoCal its the most plentiful hardwood.
I have been using a 25-27 ton and yes it will do the job but it is pretty hard on it. I don't like a machine having to work at 90-100% capacity for hours on end.
Here are some pics of the ram.
And here is the calc for it capacity.
I guess I'll be beefing up my H beam:D
/ Eucalyptus splitter. #33
Aussiebushman, I think it depends on the individual tree. I certainly would not want to fell a 500 year old red gum for firewood if I could avoid it, but if it is plentiful and much younger trees are taken, then I see no real objection to taking a few. I always preferred White Box myself.
simonsays, I noted from your opening post that you considered Red Gum a particularly difficult tree to split. You need to get out to Oz and try some of the real tough Eucalypts - spiral growth is an understatement. Or, come and help me to split some old boles of olive trees. Chainsaws are a waste of fuel and sharpening files. A bloody big hammer and several steel wedges are the only way to end up with pieces small enough to put on the stove. The olive stumps are still easier than some Eucalypts.
/ Eucalyptus splitter. #34
Alan
I dont have any on my place I've maimly got longleaf box & stringybark with some black wattle thrown in for variety I only use what has fallen but the redgums start on the northern side of town and are sort after buy people who dont know how good box is.
watching this build with interest
Most of the firewood I cut is dead and has been for awhile. Every once and a while I take a hazard tree down or find recently cut wood.
OLD Mac- The red gum I have been cutting lately has been very twisted and knotty. So it may grow differently here in California. We have many types of Euc but red gum is the best IMO.
/ Eucalyptus splitter. #36
Simonsays, I think most eucalypts are not straight grained wherever they grow. The top pic must be a very windy site!! There is a good lean on a couple of those trees.
There are enormous numbers of Eucalyptus globulus (Tasmaninan Blue Gum) here that go for pulpwood. They are used for firewood by those who cannot get anything better, but they burtn very quickly and leave a lot of ash. They tend not be so twisted as many others E. species - at least here. I did not have any on my place in Australia. You could be right about different environments making different spiralling. No doubt somebody could spend a few years researching that if they were funded.
I understand there were quite a lot of Blue Gums planted in California at one time, so you might be able to find some and see what you think of them.
Good eye OMD! That lean is caused by the infamous Santa Ana Winds. These winds cause/influence many of our wildfire conflagrations in SoCal. They are known as Foehn Winds and although they do not happen often they are Warm and Fierce. They also tend to blow opposite of the prevailing winds.
My experience is the same on blue gum. To me not preferable.
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
UNUSED IRANCH IRTPL 10000Ib TWO-POST CAR LIFT (A60432)
UNUSED IRANCH...
BUNDLE OF UNION STRUT COVERS (A60432)
BUNDLE OF UNION...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
Wanco NTCIP Towable Solar Message Board (A59228)
Wanco NTCIP...
