Everlast Welders - Welders and Plasma Cutters by Everlast
   / Everlast Welders - Welders and Plasma Cutters by Everlast #501
Mark ...I have this pluged into a 30amp 220 line and have run it at 120 amps. How far can I take it to safely? Love this machine and still trying to get acclimated.
And what is "this"?
Did my question just get put on ignore??
Mark was on travel for a while.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #502
mark was talking about the PowerARC 200ST which i just purchased and know little about stick welding. I have no room to add a 50 amp breaker and the PowerARC 200ST draws a max of 34 amps (according to the Everlast tech guy I called).
   / Everlast Welders - Welders and Plasma Cutters by Everlast #503
I have the PA200ST and I've posted how much I can get out of it on a 20 amp outlet. Look through my posts to find it. At 30 amps input, you should be able to weld with any 1/8" electrode. And don't worry about pushing the machine too hard, it will shut down to protect itself before it is damaged by heat.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #504
Thanks Dan that is what I needed to know… now I can go practice.
Been out for the weekend...just got back. As far as an answer...I don't mean to sound like it sounds, but you should consult a licensed electrician. Codes do vary somewhat though the NEC is the guideline. Some local codes may be tougher. I am not an licensed electrician, so any advice outside of that that I give has no legal weight or official recommendation and should be taken with a grain of salt. But at 30 amps, you should have the ability to take it close to the maximum...though actual inrush is around 40 amps take a look at your I1MAX listed on the units spec panel. That is your maximum amp inrush current. The I1eff is the rated amperage which is the average running amp draw. A slow trip circuit breaker or a time delay fuse should see up you to almost the max rated output on 120V.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #506
Thanks Mark …I am on a 30amp at 220 V. I will look over the unit and see what it tells me.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #507
Mark is there some way i could order a PA140, i don't need tig i already have an mts. Don't see the use of going all the way to the PA200ST, i already have a lincoln AC/DC stick welder. Besides the reason i was looking at the PA140 was that i can run it on my generator.
Being in Canada, they do not offer that model. The 140ST I think is better built internally ( there is a difference). For the price difference, getting a TIG torch is a miniscule consideration. The carry case can account for half the price difference.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #510
Thanks Mark.
Hows the manual for the iMIG 140e comming along?
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
198367 (A51243)
198367 (A51243)
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
INOP Polaris 700 (A51573)
INOP Polaris 700...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
