Exhaust coming from breather tube & Dip Stick?
   / Exhaust coming from breather tube & Dip Stick? #11
You got fual leaking into the crankcase from either the pump or injectors.
   / Exhaust coming from breather tube & Dip Stick? #12
Does your motor have sleeves? If not a check sooner than later may save a block.
Egon /forums/images/graemlins/grin.gif
   / Exhaust coming from breather tube & Dip Stick? #13
Change the oil, turn off the fuel shut-off valve everytime you shut down the tractor, and I'll bet your problem will go away. Use Shell Rotella T 15-40 heavy duty oil, and you should check the oil everytime you use the tractor to make sure it's not using or "making" oil.
   / Exhaust coming from breather tube & Dip Stick? #14
You can also use amsoil 15w-40 heavy duty diesel oil. Better numbers than rotella t But ,I'll bet it's time for a rebuild.
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
1264 (A50490)
1264 (A50490)
