Exhaust coming from breather tube & Dip Stick?
   / Exhaust coming from breather tube & Dip Stick? #11
You got fual leaking into the crankcase from either the pump or injectors.
   / Exhaust coming from breather tube & Dip Stick? #12
Does your motor have sleeves? If not a check sooner than later may save a block.
Egon /forums/images/graemlins/grin.gif
   / Exhaust coming from breather tube & Dip Stick? #13
Change the oil, turn off the fuel shut-off valve everytime you shut down the tractor, and I'll bet your problem will go away. Use Shell Rotella T 15-40 heavy duty oil, and you should check the oil everytime you use the tractor to make sure it's not using or "making" oil.
   / Exhaust coming from breather tube & Dip Stick? #14
You can also use amsoil 15w-40 heavy duty diesel oil. Better numbers than rotella t But ,I'll bet it's time for a rebuild.
2007 KENWORTH T600 (A52472)
2007 KENWORTH T600...
1977 CATERPILLAR D6D (A52472)
1977 CATERPILLAR...
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
