extra hydraulic on a L3130
   / extra hydraulic on a L3130 #11
Don,
If the lever has a 'detent' position in one direction, then that would be the float position. If your lever returns to neutral after pushing it all of the way up/down, then it would be non-float. They work just like the float detent on a FEL joystick.
   / extra hydraulic on a L3130 #12
Don:
Larry supplied the answer. You can get the valve blocks either way. I use the non-float for the round bailer door and the float for the mower.
   / extra hydraulic on a L3130 #13
Thanks ljh2 and 5030, One of these days I'll take off the BH and figure out which one I have. It has been about 5 months since I briefly worked my box blade with T&T at the dealer.
SC Dolphin, you do not have to "factory order" the remotes. The Dealer can install them anytime. The Hydraulic cylinders for T&T are obtained from various third parties by you or your dealer. My dealer just happened to have a set of Gearmore T&T cylinders in his office and I told him to "hook em up". /forums/images/graemlins/smile.gif
TEST BID LOT (A50775)
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
AGI - Westfield MKX 13-94 Swing Away Auger (A50514)
AGI - Westfield...
2018 FABRIQUE 20FT TRAILER (A52141)
2018 FABRIQUE 20FT...
