extra hydraulic on a L3130
   / extra hydraulic on a L3130 #11
Don,
If the lever has a 'detent' position in one direction, then that would be the float position. If your lever returns to neutral after pushing it all of the way up/down, then it would be non-float. They work just like the float detent on a FEL joystick.
   / extra hydraulic on a L3130 #12
Don:
Larry supplied the answer. You can get the valve blocks either way. I use the non-float for the round bailer door and the float for the mower.
   / extra hydraulic on a L3130 #13
Thanks ljh2 and 5030, One of these days I'll take off the BH and figure out which one I have. It has been about 5 months since I briefly worked my box blade with T&T at the dealer.
SC Dolphin, you do not have to "factory order" the remotes. The Dealer can install them anytime. The Hydraulic cylinders for T&T are obtained from various third parties by you or your dealer. My dealer just happened to have a set of Gearmore T&T cylinders in his office and I told him to "hook em up". /forums/images/graemlins/smile.gif
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
Year: 2008 (miles exempt o title) Make: Volkswagen Model: Passat Vehicle Type: Passenger Car (A51694)
Year: 2008 (miles...
Bush Hog RMB 1865 Ditch Bank Mower (A50120)
Bush Hog RMB 1865...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
