extra hydraulic on a L3130
   / extra hydraulic on a L3130 #11
Don,
If the lever has a 'detent' position in one direction, then that would be the float position. If your lever returns to neutral after pushing it all of the way up/down, then it would be non-float. They work just like the float detent on a FEL joystick.
   / extra hydraulic on a L3130 #12
Don:
Larry supplied the answer. You can get the valve blocks either way. I use the non-float for the round bailer door and the float for the mower.
   / extra hydraulic on a L3130 #13
Thanks ljh2 and 5030, One of these days I'll take off the BH and figure out which one I have. It has been about 5 months since I briefly worked my box blade with T&T at the dealer.
SC Dolphin, you do not have to "factory order" the remotes. The Dealer can install them anytime. The Hydraulic cylinders for T&T are obtained from various third parties by you or your dealer. My dealer just happened to have a set of Gearmore T&T cylinders in his office and I told him to "hook em up". /forums/images/graemlins/smile.gif
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
2015 Volkswagen Jetta Sedan (A50324)
2015 Volkswagen...
Toro Workman Utility Cart (A51694)
Toro Workman...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
