F150 ecoboost drilled my intercooler
   / F150 ecoboost drilled my intercooler #101
I too drilled my inter cooler. I got no water and saw no performance change.
Did they check out the inter cooler by removing the bottom hose?
When you started your story I thought for sure it was the vacuum powered front hubs or a carrier bearing on the drive shaft.
Chris
   / F150 ecoboost drilled my intercooler #102
Ok, so here we are - got the truck back from Roswell Ford who wanted to do the TSB for the intercooler basically making it less efficient to prevent condensate. I said no thank you, took my truck back and brought it to a local mechanic who drilled the whole for me (didn't have the right tools with me as I am travelling). When we drilled the hole, nothing came out. When we rev'd the engine with the foot on the brake, nothing came out. Took it for a test drive without the trailer first and on the first hill got the misfires again. So the best thing I can say is that it is most likely NOT due to intercooler condensate at this point in time, which, of course, means the Ford TSB would not have helped at all. We are no worse off at this point. The local mechanic is going to look at a few things, including fuel pressure today.
   / F150 ecoboost drilled my intercooler #103
Ok, so originally I thought we had a transmission problem - was not thinking misfire, but the original service mgr who has 17 years experience said it was definitely misfires.. And, of course, now we are getting P0300 error codes, which is a random misfire.
Chris
   / F150 ecoboost drilled my intercooler #104
If it's a miss fire there are only 3 possible culprits. Coils, Boots, or Plugs.
Chris
   / F150 ecoboost drilled my intercooler #105
There's one other. And that is a faulty or plugged egr. It will create a lean miss at part load. They do not always throw a code either.
   / F150 ecoboost drilled my intercooler #106
Hmmm, my original dealer said my VIN does not have an EGR!
   / F150 ecoboost drilled my intercooler #107
Chris
It may come down to coils. I'm just stymied why all 6 would fail at roughly the same time.
   / F150 ecoboost drilled my intercooler #109
Miss under load mean you possibly have a clogged fuel filter.
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
40' High Cube Four Multi Doors Container (A55272)
40' High Cube Four...
2021 AIRMAN PDS100S-6E1T4 PORTABLE AIR COMPRESSOR (A52709)
2021 AIRMAN...
Portable Restroom (A54865)
Portable Restroom...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
Blue Diamond 103709 (A53317)
Blue Diamond...
