dalola
Platinum Member
- Joined
- Jun 12, 2017
- Messages
- 682
- Location
- Ohio
- Tractor
- Kubota BX2380 w/FEL, Woods RM48, Yazoo/Kees Max2 ZTR
I'm on my second 2.7EB F150, had a '15, now an '18. Both have performed above expectation, with zero issues. The 2.7EB is a heavy-weight puncher despite it's small displacement. With a tune, it's even more impressive, as Ford left considerable margin on this engine. Tho I only tow between 4-6K, the 2.7 is capable beyond that with a correctly configured truck. I would choose this engine for all tasks up to 7K towing. It offers the best of everything; cost, power, & efficiency. For heavier towing duty (>7K), I would opt for the 3.5. The 5.0 is also a competent engine, but once you get used to the instant torque of the EB's, it's hard to feel comfortable with an NA motor again, especially in a truck.
If you're serious about purchasing, I would suggest a thorough test drive of the 3 popular engines, the 2.7, 3.5, and 5.0. All are great performers, but each drives with a noticeably different feel. Depending what feel you like, will likely determine your choice of engine. Again, no bad choices here, but they are quite different in their behavior.
Good luck!
Good luck!
