F350 to F450 suspensions
   / F350 to F450 suspensions #21
I guess if looking to buy used, one must pay close attention to specs.
Just found the CNC trucks on the website. (I wasn't looking under commercial vehicles)
The 350/450/550 are all real similar when comparing apples to apples. IE: same engine, wheelbase, etc. The 450 and 550 weigh the same and the 350 is only a few hundred behind.
The 350 is 14k gvwr. And 7800# payload in 4wd.
The 450 can be had in 15k, 16k, or 16.5k gvw.
The lighter gvwr can only haul a few hundred more than the 350. And yes, the 16.5k can haul 9500 ish.
But the point I made earlier remains. The gap between the 350 trucks and the 450 trucks have narrowed. Because you can get 15-20 year old 450's with 16-16.5k ratings. Whereas the ton trucks of 20 years ago were in the 11-12k range
   / F350 to F450 suspensions #22
the V10 does okay? I was looking at one of those to have around.
This is my 3rd V10 dump. First was a 350 4x4 basic XL package.. I think it was a 2009. Nice truck but. I ended up trading to a F350 diesel dump ..think it was a 2012 or 2013. Had some issues with it and traded it for a 2014 F450 with the V10 and that one had the auto 5 speed trans. .. I found that truck extremely uncomfortable being 6-2" and traded it for the new body style F450 V10 with the. 6 speed auto. ..there is a night and day difference between the 5 speed and the 6 speed. The truck pulls way better and way smoother. ..it still loves fuel though. While I didn't buy it for its fuel economy..it's brutal. 6-7 mpg is what it gets. ..
   / F350 to F450 suspensions #23
I was indeed looking at the pickup version of the 450, because I couldn't find on Ford's website where the CNC trucks were.
And both 450 and 350 in pickup trim both show the 9900 rawr
My F45o is a C&C ..not a pickup truck. I believe the GVW was just shy of 17k ... I had thought about getting the F550 for another 1500.00 or so..but opted for a aluminum dump body that weighs quite a bit less than a steel one....and won't rust ..which allows me to increase my payload...and the payload number is quite a bit higher than what you had posted.
   / F350 to F450 suspensions #24
I had a 2000 F-450 with an aluminum dump. 7.3L diesel. I liked it a lot, but couldn’t dump rocks or heavy stumps in it without some scrap plywood in the bed. 15,000 GVWR.
   / F350 to F450 suspensions #25
That’s the single biggest reason I got rid of the 3500HD I had. For those not familiar the 1990s 3500hd was the 450-550 of that period. I figured if I was going to get terrible mileage I might as well drive my Topkick and haul 10 tons.
   / F350 to F450 suspensions #26
I think we all know the 350s aren’t made to haul 7800 pounds every day. They’ll be junk in short order doing that. There’s a reason the commercial trucks are de rated over the bragging war pickup trucks. The 450s will haul 7800 pounds every day. Have you looked over the trucks close? There’s a big difference.
   / F350 to F450 suspensions #27
I work on a fleet of 5 or 6 ford F450's everyday. Ranging from 03 to 07. One short wheelbase 4wd that used to have a utility body, now a flat bed and 6.0, One 4-door 2wd with 7.3l and a dumping flatbed, one 2wd with a dump body and 6.0, one 2wd 6.0 with just a plain flatbed, and one 2wd with 6.0 that has a LONG flatbed and dovetail for hauling mowers.
They all are ~16k or 16.5k GVW's. They ALL weigh in the 10k-11k range empty. giving them ~3-ton payload capacities.
I have a '16 ram 3500 CNC. And aside from the 450's having 19.5's.....there really isnt a whole lot of difference.
So....to answer the question.....YES I have looked over the trucks closely.
A 4wd, 169" WB, 6.7L F350 CNC weighs 7260#
A 4wd, 169" WB, 6.7L F450 CNC weighs 7783#
Thats only 523# heavier for the F450. And the F550 weighs the SAME as the F450
The F450 and F550 have 19.5" wheels/tires and larger brakes front and rear. (which takes up probably a good bit of that 523# difference)
Cannot find anything that differentiates the front or rear axle ratings??
Not trying to start a debate or pi$$ing contest. But aside from the 19.5" wheels/tires and larger brakes....with what little that is left of the ~500 pound difference is the 350 vs 450 quantify's saying that the 350's arent made to haul 7800# everyday or they will be junk in short order? And conversely.....just WHAT would allow the F450 to haul its max of 9800# everyday and NOT be junk in short order?
And while on the topic...since they weight the EXACT SAME.....and according to any relevant spec I can find online.....just what is different on the new F550 that allows it to carry even 3000# MORE than the F450?
Lets think about this.....a 7200# curb weight truck carrying ~7800# everyday is gonna be junk in no time. But somehow a 7700# can haul around 12,000 pounds everyday? You think an added 500# of curb weight makes that much difference?
Honest questions. As I have stated, I have intimate experience with ~15 year old F450's. ANd with a 4 year old dodge CNC. Not so much with these bran new ford CNC's. But on paper it just looks like the F450 is a derated F550 with a different emblem. And that the F350 is quite a capable truck and nipping on the heals of what ford has chosen to derate the F450 to??
   / F350 to F450 suspensions #28
450 and 550 are basically same, 550 has heavier 14,000lb rear axle and maybe a little extra frame reinforcement. Mines an older 550 (‘08), but tows 13-14 tons on a weekly basis and has done so for 9 years.
   / F350 to F450 suspensions #29
Wouldnt that make the F550 a little heavier? Ford list the curb weights the EXACT SAME for the current 2020 models?
   / F350 to F450 suspensions #30
Unless it’s really a 14k on the 450.
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
3 Forks (A56857)
3 Forks (A56857)
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
