F350 vs competition
   / F350 vs competition #101
I love my 2000 7.3, I have done some mods to the motor and trans.it pulls really well. I hope it can be the last truck I own for pulling the equipment to jobs. I will rebuild it when it comes time, right now it has 330,000 on it and it runs great.
John
330,000 sure cant complain about that!
   / F350 vs competition #102
John
   / F350 vs competition #103
to everyone who is complaining about the 4.30 gears in the Ford, if GM or Dodge offered lower gears form the factory, they would have tested them with them. Fact is Ford offers 4.30s in their 1 ton, the other two don't.
   / F350 vs competition #104
I wonder what most of the Fords roll out the line with? Like has been said by others, the test was stacked and Ford knew it.
   / F350 vs competition #105
Explain why the test was stacked. How exactly was it stacked? Seriously, there was no stacking. Ford picked the vehicle with the highest tow rating from each of the big 3. The HIGHEST TOW RATING IN THE 1 TON CLASS FROM EACH OF THE BIG 3! The best each had to offer. There was no stacking. Simply, in order to get a better tow rating, Ford offers 4.30 gears. The others do not. So, if you want to tow the most, are you going to pick a Ford with only 3.73 simply because the others don't offer it? Or are you, the customer, going to pick what gets you the best.
Seriously, this isn't rocket science. The only ones saying it was stacked are those that are miffed because their brand lost. Get over it. Your brand doesn't offer 4.30 gears. That's not Ford's fault.
   / F350 vs competition #106
Explain why the test was stacked. How exactly was it stacked? Seriously, there was no stacking. Ford picked the vehicle with the highest tow rating from each of the big 3. The HIGHEST TOW RATING IN THE 1 TON CLASS FROM EACH OF THE BIG 3! The best each had to offer. There was no stacking. Simply, in order to get a better tow rating, Ford offers 4.30 gears. The others do not. So, if you want to tow the most, are you going to pick a Ford with only 3.73 simply because the others don't offer it? Or are you, the customer, going to pick what gets you the best. Seriously, this isn't rocket science. The only ones saying it was stacked are those that are miffed because their brand lost. Get over it. Your brand doesn't offer 4.30 gears. That's not Ford's fault.
I don't think this is the most accurate statement. The ford at least from this test may be the fastest but isn't the ram still rated to tow the most?
   / F350 vs competition #107
We don't know since this is a 2015 F350. The tow ratings haven't been released, but my money is on it beating the Dodge. But, nit-picking aside, let me rephrase my question:
"So, if you want to tow the most the fastest, are you going to pick a Ford with only 3.73 simply because the others don't offer it? Or are you, the customer, going to pick what gets you the best."
   / F350 vs competition #108
We don't know since this is a 2015 F350. The tow ratings haven't been released, but my money is on it beating the Dodge. But, nit-picking aside, let me rephrase my question: "So, if you want to tow the most the fastest, are you going to pick a Ford with only 3.73 simply because the others don't offer it? Or are you, the customer, going to pick what gets you the best."
So did ford do a complete redesign for 2015? The reason ram obtained those numbers is by a whole new 50,000 psi frame and new suspension. If ford rates their truck over ram without a new frame everyone with the older under rated ford 1 tons should call bs.
   / F350 vs competition #109
No, it's not a complete redesign. Why should the owners of older trucks call BS? Ford is upping the power of the PowerStroke, updating the torque converter, and making other modifications. There are probably a few frame updates as well, but it's not an all-new truck. It doesn't have to have a whole new frame to increase tow ratings... :rolleyes:
   / F350 vs competition #110
How long has ford used the same frame and continued to increase the ratings. I have a 2011 250 a 2008 f 350 and a 2011 F450. If the ratings go up for 2015 with the same frame and suspension I call bs because I can't haul that with my older models. Because ford either under rated the old ones or is over rating the new ones. And don't say it's engine or torque converter related because the 450 I have has a v10 in it and if it'll haul that weight in a 450 frame it can haul it in a 350 frame.
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2014 John Deere 1770NT PLanter (A53485)
2014 John Deere...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2018 K-TEC 1228 PULL TYPE DIRT PAN (A52707)
2018 K-TEC 1228...
