Fault codes
/ Fault codes #1
Normando1
John deer 310sg
F460 fault code John deer 310sg
/ Fault codes #2
That code is: "Input air temperature reads low."
I believe that this is one of the inputs to your Engine Control Computer (the ECU). It could be a bad temperature sensor or a broken wire between sensor and computer.
But it could also indicate a problem with the computer module itself. ECUs are a known trouble component. The frame mounted ECUs get a lot of engine heat and water & end up leaking or swelling up and breaking their internal printed ciruit.
Non-repairable. Replace with new.
I just had the ECU replaced on our 310SG. My error code was coolant temperature instead of air.
rScotty
CATERPILLAR WHEEL LOADER (A65053)
CATERPILLAR WHEEL...
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
213064 (A64276)
213064 (A64276)
