FEL Tractor Crane *Proof of Performance*
   / FEL Tractor Crane *Proof of Performance* #41
Yup you can extend the backhoe for extra tipload... and break the front axle...
Be careful with what you do to a farm tractor... :)
   / FEL Tractor Crane *Proof of Performance* #42
lift frame.jpgI saw this thread quite some time ago and have been wanting to share the pictures of the 3-point hitch crane (technically a jib) I whipped up to use on my little B6100's 3-point hitch this past fall for putting up trusses for my shop building. It sure does look funny to have a 24' long piece of steel tubing attached to the back of the machine. What I did was put a 5' wide piece of 3"x3" 1/4" wall tube at the bottom to set on the floor/ground when lifting to try to keep everything stable and mount a winch on the bottom, with a pulley block on the top. Honestly, the whole set up was a little sketchy as first, and you don't want to drive under power lines, or go above low first gear when moving, but the implement probable saved me 2-3 grand in rental fees since I only had the weekends to put the building together. The whole thing was whipped up in an evening, so there's nothing pretty about it. I didn't even paint the implement (unheard up at my shop), but once I got the feel for using it, it worked slick. Check out the pictures everyone:
P.S.
Please don't judge my fabrication work on this project. It was whipped up in 4 hours after a 70 hour work week. It's ugly ugly ugly (there's not even any TIG welds on this thing), but it got the job done. :) Basic details on the garage: 24'x32' footprint with 11' walls (total height with bottom plate, top plate, and concrete knee walls) , roughly 20' ceilings in the center, and 10'x10' garage door. I'm still rocking the tyvec and saving my pennies for the siding.
Tandem Axle Rear Trailer Frame (A55852)
Tandem Axle Rear...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
2007 International 4300 (A53314)
2007 International...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
