FEL woes
/ FEL woes #1
Deerlope
Veteran Member
Northern, New York
Kubota L3830 03: RTV 900
What has anyone done to make your FEL raise and curl at the same time? Neither my L3830 nor my M-5040 will do this. My dealer said that he set the FEL pressures to factory specs. JD's 4320 will do it right off the lot because I just tested one about an hour ago.
/ FEL woes #2
This really suprises me. I recently purchased a b2620 which is a lot smaller than the models you mention and mine also does this right off the lot. Actually when I was at the Kubota dealer test driving the couple of models I was interested in the salesperson actually showed me this as a nice feature to have.
/ FEL woes #3
Without going out and starting my machine, my recollection is this:
The little sticker indicating permissible actions with the loader stick, the only "blank" in the eight different directions you can push the lever (N-S-E-W, and the 4 combinations of the cardinal motions, NE-NW-SE-SW) is the "SW" motion indicative of raising and curling the bucket simultaneously.
I believe I can perform the task, however, under a "no load" condition. The bucket will curl and the loader booms will raise simultaneously UNTIL the bucket reaches the "full curl" position. At that point, the hydraulic circuit is open and the loader booms stop rising. If I release the curl circuit (slide the stick from the SW position to the S position), the loader booms will resume raising.
If the bucket is curled under load at the same time the booms are asked to raise, the same thing will happen. FAR more strength in choosing EITHER curl or raise. Doing both simultaneously IS POSSIBLE on even the BX, just not under much of a load.
I think you'd have to have some type of seperated systems that is not common in "normal" machines to have full strength in this particular FEL action.
46196SFL (A64557)
46196SFL (A64557)
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
Cowboy Statue (A64557)
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
