Fence posts and CCA
   / Fence posts and CCA #11
>Ask this question. If CCA is SOOOOOO bad why has the
EPA NOT recommended or ordered the removal of all exposed CCA treated wood?
It's just a matter of time? CCA is the next abspestos. I agree, it's a load of huey. But these decisions are not generally rational.
   / Fence posts and CCA #12
All the radon testing people needed somthing new to test because people figured out that was BS... So CCA, Yea, if you worked in a manufacturing plant and spent most of your life there you might get poisended. If your built decks for a living you might have an issue. The average Joe doesnt have an issue. CCA has been around for a long time for children playgrounds, decks, fence post.
   / Fence posts and CCA #13
re Cedar posts lasting only 10 years (or 6). My experience with both cedar and cca 4x4 is the same. If you get 10 years out of either one you are lucky.
Harry K
   / Fence posts and CCA #14
</font><font color="blue" class="small">( My experience with both cedar and cca 4x4 is the same. If you get 10 years out of either one you are lucky )</font>
What CCA treatment level did those posts have? I've seen as low as .25 sold in box stores, which isn't rated for ground contact. For a while in Florida, Lowes and HD were selling PT lumber for exactly the same price. Trouble was, the Lowes PT was .40, while the HD stuff was only .25.
It pays to check and see what you are getting--or how bad you are getting had. /forums/images/graemlins/grin.gif
SnowRidge
   / Fence posts and CCA #15
I did (and do) check. I have used them at various times over the years and buy them at a -real- lumber yard. All were ground rated. My lates ones were the fence arount my dish antenna. rotted at ground level in ca 10 years (not sure exactly. Of course the usual 4x4 post are -not- made of the greatest grade of wood.
Harry K
   / Fence posts and CCA #16
If you are near saltwater, you might be able to find PT with much higher retention ratings. I used to buy PT with a 2.5 rating. The yard that I bought it from specialized in lumber for saltwater applications, and I think the lowest rating they carried was .60.
Interestingly, most of their stuff wasn't dimensional either. When you bought a 2x10, you got lumber that really was 2 inches by 10 inches. Of course, it all cost quite a bit more than the stuff at the 'Borg.'
By the way, it all came from a supplier in Georgia--and was for 'Professional Use Only." /forums/images/graemlins/grin.gif
SnowRidge
   / Fence posts and CCA #17
I've got cedar posts in Bastrop that I cut and skinned myself that I planted 18 years ago and they're still there -- They're showing age - but they're still doing the job. I think skinning the bark off is key.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2016 FORD TRANSIT 350 CARGO VAN (A59575)
2016 FORD TRANSIT...
Pallet of 10 Chains and 5 Binders (A57453)
Pallet of 10...
Mini John Deere Truck (A55853)
Mini John Deere...
