fence unroller/stretcher
   / fence unroller/stretcher #1
Rowdius
Nugent, Texas
Kioti CK35 With KL130 Loader
Well, I just bought this: http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_28367_-1______?rFlag=true&cFlag=1
I've never liked stretching wire with a tractor, though I've done it with some success. I may just use it as an unroller and use my manual stretcher, we'll see. Just got tired of wrestling wire by myself.
Also, did a job today with my boxblade clearing and leveling a lot that is going to be used for a softball field. $200 for three hours of work, and the customer was really impressed. If I ever get caught up on the homestead I might start looking for some paying jobs again, but there is just too much to do at home right now.
   / fence unroller/stretcher #2
Neat.. I havn't seen one at tsc down here... hmm.. I may have to weld one of those up!
how many clams was it?
soundguy
   / fence unroller/stretcher #3
The link is broken for me and I can't seem to find it with a manual search on their site. :( I don't see any really obvious lock on it to use for stretching the fence though.
I'll second Soundguy's question. $? I'm having a deer problem and may have to stretch out a bunch of fence. It'll be a lot taller than 4' though, so I might have to build a big spool to help unwind it unless it comes in an 8' or 10' version.
   / fence unroller/stretcher #4
Soundguy, it is $283.17 in Killeen, Texas.
http://www.tractorsupply.com/webapp/wcs/stores/servlet/ProductDisplay_10551_10001_28367_-1______14345|14346|14358|28367?listingPage=true
The website lists it as $283, but the two TSCs around here list them at $269. It is on page 158 of their blue book.
hmm, I am not sure why the link is not working here. If you copy and paste it into your browser it works though.
The opening is 65" tall, so that is about the limit on height.
As for stretching, the vertical piece on the back is actually two pieces. At the top, between the bar that holds the wire and the back vertical you can see the hinge. When you begin you open that hinge, run the wire between the two pieces of angle iron and unroll the wire. Once you get to the end of the run, you close that hinge and three bolts sandwich the wire between the angle iron for stretching. Though if one was afraid of over stretching with it they could just bypass that part and place their manual stretchers on that vertical bar.
   / fence unroller/stretcher #6
   / fence unroller/stretcher #7
Bummer.. our TSC stores here in FL don't have them yet.. went by today to look and manager said not yet..
thanks for the info.
soundguy
Well, I used the unroller today, and it worked pretty good.
I had to turn out of the pin to the inside to make it fit my yanmar, but that is pretty common with my little tractor. What I was not expecting was the little birdblock that kept my lift arm from being able to slide over the pin once it was towards the inside. Instead of cutting it to fit, I made a spacer to extend the pin out far enough.
My little yanmar 1500D is pretty good for this application though. Since it was orginally designed to pull a tiller at really low speeds, I have extremely low gearing that allows me to stretch fence without over stretching. That worked out well. However, I will have to add more weight to the front to get a little more traction. I have the weights (about 90lbs that I bought for $20 bracket and all) I just needed to buy some bolts.
I only stretched 200 feet of wire today, but it went really fast once I worked out the little problems of getting the unroller onto the tractor.
Here is the old fence before I removed it:
After removing the old fence and running over it with the boxblade (I should have ran the shredder over it too, but...)
Just need to add a few strands of eletric and it is done.
These gals are not happy now that they cannot escape this paddock to come see me up at the house.
   / fence unroller/stretcher #9
That's pretty slick looking and compared to the cost of a simple carry-all it's not a bad price. I wonder if it would work on snow fence though...
I have no idea. I've only seen snow fence once in my life, and that was because someone had it pressed into service to contain a small dog.
   / fence unroller/stretcher #12
Rowdius, that looks exactly like what I have to do -- except my old fence is in much worst shape, and my goats are black not brown. Do they eat the shingles off the side of the house when they come to visit?
If I could do 200 feet a day I'd be thrilled. What kind of woven fence are you using? Is that the redbrand from TSC?
No, but the last time they came up, they grazed down all the rye grass in the yard, keeping me from having to mow until spring.
Yes, it is Redbrand. I've had good luck with them in the past, but this time I am having to go with the lower end of Redbrand, which worries me... but we'll give it a try. It's $125 for a twenty rod roll.
   / fence unroller/stretcher #14
Buncha cheaters! One of those setups would have been nice. I've unrolled and stretched 7 - 100' rolls of 5' tall, 2"x4" opening heavy duty horse fencing to keep our sled dogs in the yard. That stuff weighs a ton! Took 3 guys to get the rolls it into my truck when I bought it, and I had to unload it myself. My wife wanted me to put up more fencing, but I told her I wasn't doing another 600' by hand. I guess I could tell her about this rig after I get my tractor.
I have one more roll to unroll & stretch this weekend. It's even more fun struggling with it in the snow. Had to shovel out the fence line to get the last 3 rolls installed. Ended up dragging some of the rolls to their starting point on a sled. And of course, there isn't a flat area anywhere along the fence line.
Had our 16 year old help me get 2 rolls up, and you'd think I was asking him to help me move 10,000 lb concrete blocks. I had to keep reminding him as he's grunting away and not doing much, that I've done 5 rolls all by myself.
Kids today. :D
   / fence unroller/stretcher #15
I made one based on this one I saw at my brother's place.
Here is mine.
Some construction details:
Finished
Mine tightens with 2 levers. Works pretty good. I tore it up a little backing sideways into a tight spot to apply tension. Broke a weld and twisted it to the side. Fixed it last weekend. I've stretched about 3500 feet of goat fence so far.
   / fence unroller/stretcher #16
Nice!
soundguy
UNUSED RAYTREE RTSG30-30" HYD STUMP GRINDER (A60432)
UNUSED RAYTREE...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2016 Chevrolet...
