Fenceman doing what fencemen do these days
   / Fenceman doing what fencemen do these days
Hmmmmm, looks like you got it on the down hillside and it's going to get easy now. /forums/images/graemlins/grin.gif
For those of you who are considering sighting in keep in mind it's the way things were done long before we had string.
I worked with a guy that was a hod carrier for a bricklayer that never touched a string. He claimed the bricklayer was the most productive one he ever work with and his work was perfect.
The easiest way to start is to put your end posts up. Make sure they're plumb. Have a helper go to your second post in line and holding it plumb move it in and out of line for you.
What you're looking for is the line post while plumb to cause the other end post to disappear, but barely.(helpers get hard heads from being smacked repeatedly and often for not hold the post plumb while moving the post. It is not recommended to have your wife be your helper in this endeavor if you're wanting to maintain an active, uh, er, uh, marital discourse.) /forums/images/graemlins/blush.gif
When the second post is perfectly in line you have the helper move back to the first line post and plumb it in with you sighting in between the second line post and the end post at your end.
After that it's you sighting in from behind the last line post going towards the far end. So you'd move to the second line post and sight in the third looking down line.
If the height is uneven you can temporary some height posts just a tad out of your fence line to help you gauge height. Do have them out of line enough to not confuse you and you start sighting in to them.
Once you get used to what you're wanting to see when the helper is got the post where you want it then you can start doing what I do, backsight.
I'm moving the post just like the helper, plumb, in and out of line. But I'm looking for the same picture you saw when sighting in the helper.
The key to this is to get the post where you want it and then go back to the previous post and sight back down the line to the target post to verify the location is correct.
The reason there isn't many fencewomen isn't because of sexual bias. And it isn't because they're not tough. You don't know tough until you've seen woman tough.
It's because there isn't many books out there explaining how to do fencing the way the pros do. If you've ever done a project with a woman I'm sure you know what I'm talking about. If the way you're doing something isn't like the way they read it being done then you're doing it wrong. /forums/images/graemlins/grin.gif
Now, StevenPaul, if you look down your line and you feel like the next one will be better, you've got what it takes to be a fenceman.
I welded up that line I was so proud of yesterday. I was emotionally sick by the end of the day. It was only a week between setting and welding. But in that week we seven plus inches of rain. That affected the clay. Some of my posts moved, not a lot, most folks wouldn't have seen it. But what I thought of was my best line ever ended up being just another line.
I can't wait for the next oppportunity to do a thousand plus feet line. But this time I'm going to try to make it the best one ever.
It'd be a bear to die and not have done that.
   / Fenceman doing what fencemen do these days #82
</font><font color="blue" class="small">( ( The reason there isn't many fencewomen isn't because of sexual bias. And it isn't because they're not tough. You don't know tough until you've seen woman tough.
It's because there isn't many books out there explaining how to do fencing the way the pros do. If you've ever done a project with a woman I'm sure you know what I'm talking about. If the way you're doing something isn't like the way they read it being done then you're doing it wrong. ))</font>
My wife would be smacking you right now if she could reach all the way to Texas... /forums/images/graemlins/blush.gif
</font><font color="blue" class="small">( I can't wait for the next oppportunity to do a thousand plus feet line. But this time I'm going to try to make it the best one ever.)</font>
Betcha say the same thing when that one's complete too.
My wife would be smacking you right now if she could reach all the way to Texas... /forums/images/graemlins/blush.gif )</font>
That's why the Canadiens came up with "truth hurts". /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( Betcha say the same thing when that one's complete too.)</font>
At my age complaining about it is almost as good as doing it. /forums/images/graemlins/blush.gif
)</font>
Yesterday was a good day. My son and a friend of his worked with me stretching and tying the V-Mesh. We got twelve hundred feet stretched and tied in about nine steady getting after it hours.
Each roll weighs about two hundred and eighty eight pounds. That's for about a hundred and sixty five feet. So we got to have intimate moments with six rolls of wire.
Here's my son so excited about following in his father's footsteps.
On five (58") foot V Mesh there's fifteen pairs of twisted horizontal wires. They have to be stripped of the connecting V wires where you're terminating the fabric.
This can not only be a pain in the butt. It's hard on the hands too.
V Mesh is especially difficult to stretch and even on long lines I try to stretch each roll. Stretching that often is really hard on the two boards and a bunch of bolts and nuts system. So I came up with a friction stretcher.
The principles are simple. First you make it heavy. I made mine very heavy. It's heavy enough that it produces a grin from me every time someone else picks it up for the first time.
First you slide the fabric between the guide rods.
Then you fold the fabric around the floating rod.
It is critical that the fabric be folded around the floating rod. That means where it's touching itself, enveloping the rod.
I use a Maasdon Power Pull come a long. Even though most of the time I use the tractor as the anchor. I'm still using the come a long because it's easier to gauge how tight I'm pulling the fabric. (when I can't pull it any tighter, it's tight enough) /forums/images/graemlins/grin.gif
I've never had the stretcher break a wire. I've also never had it slip when I've had the wires folded around the floating rod.
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2024 JOHN DEERE 1025R LOT NUMBER 109 (A53084)
2024 JOHN DEERE...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
