Fertilizer spreader mounted on a FEL
   / Fertilizer spreader mounted on a FEL #1
countrybumpkin
Elite Member
Kioti, kubota
I was wondering if anyone has converted a rear three point hitch spreader to a hydraulic driven one mounted on a FEL? I was looking at maybe doing this in order to "multitask" while working my food plots. Looking at removing the PTO shaft and mounting a hydraulic motor to it and run it off my front auxiliary port, any thoughts or opinions? I was thinking of something like this one.
   / Fertilizer spreader mounted on a FEL #2
I'm trying to understand any advantage gained by putting it on the FEL?
Are you thinking of spreading the fertilizer as you pull a disk/tiller?
   / Fertilizer spreader mounted on a FEL #3
Given the cost of fertilizer, I'd sooner pay strict attention to maintaining a constant ground speed and keeping my application rate on target than "saving" a trip across a food plot. The bottom line here for me is, you are looking to spend $$$ on a project to ensure you waste $$$ on rate and swath control of your fertilizer application.
   / Fertilizer spreader mounted on a FEL #4
I have thought of the same thing many times. I would be running it on the front end of Toolcat. I was actually going to build a 3 pt adapter plate so I could run other 3 pt attachments also. Problem is I have never actually got around to doing it.
   / Fertilizer spreader mounted on a FEL #5
I have an idea in mind to mount an electric seed spreader on the back of my disc harrow to do my food plots more efficiently. I'll just weld a 2 inch reciever tube on the back of the harrow, then rig up the seed spreader to mount right into it. Controlling the speader motor is easy, a simple cable (with a connector) and a switch wired to the battery will run the motor. Working the feed gate remotely to adjust the seeding rate will be a little bit tougher. Need to start looking at what's out there to see what I can do.....
   / Fertilizer spreader mounted on a FEL #6
It will work on days that are not too windy. Otherwise, the tractor and operator will have blow back on them. Ken Sweet
   / Fertilizer spreader mounted on a FEL #7
And you DON'T WANT that fertilizer getting caught in the little nooks and crannys of your frame, grill, sheetmetal, etc.... That stuff is just too corrosive.
   / Fertilizer spreader mounted on a FEL #8
I sure like the fact that you are thinking "outside the box", what I like even more is the fact that here on TBN, you get constructive criticism on your ideas.
   / Fertilizer spreader mounted on a FEL #9
I'd look for a 6-8 ft wide drop spreader and adapt it to your FEL. Would be easy to do if you have a quick attach skid steer adapter on your FEL arms. I prefer drop spreaders to broadcast type--less messy, less overlap and ground driven so you don't have to mess with additional hydraulics.
   / Fertilizer spreader mounted on a FEL #10
The thought of multi tasking is good, but your driving into what your spreading and your gonna spend a lot of time cleaning your equipment afterward. Especially with lime or fertilizer!
Club Car Electric Utility Cart (A55851)
Club Car Electric...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2014 Ford F-350 4x4 Ext. Cab Palfinger PSC4216 2 Ton Crane Service Truck (A60460)
2014 Ford F-350...
Krause 4223 Field Cultivator (A59814)
Krause 4223 Field...
John Deere TX Gator (A60462)
John Deere TX...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
