filling in waterway with gravel ? Help
   / filling in waterway with gravel ? Help
thanks guy for the input. I kind of thought large rocks would be needed, a culvert is even a better idea, or maybe one little bridge over it so I can get to it to cut it with my 4110 jd. the trouble is the way the ground lays I would be crossing it from left to right with every pass. I think I better just leave it alone and make it like two boxes, cut one box then cross the ditch and cut the other box using a bridge or culvert. Hay its nature let it be I guess.
thanks guys.
thanks guys.
   / filling in waterway with gravel ? Help #13
One thought... I've seen people clear brush from a drain area... only to allow the water to move much faster and generating erosion where much less existed before...
I'd leave all the brush along and in the drainage area proper... except for the place where you need to cross... There, you could install a culvert with rock on the sides and on top... making a roadway over the drainage area.... and I'd let the road way dip if possible at the natural drainage point.... thus if a gully washer comes and is too much for the culvert, then it will wash over the road and stay in the natural banks... Just a thought.
   / filling in waterway with gravel ? Help #14
good and welcomed advice. I also thought I would plant some grass for water way that I used at my river camp banks with some luck. I am taking the clearing slow as to not remove all plant life becasue this 1.5 acres is all in a steep valley. So I clear a bit then sow grass or ground cover. Cutting large vines out of the trees as I go. Some of the vines are as thick of my arm. Most be very old but they are choking the trees.
Any way thanks for the advice.
Roger
Roger
   / filling in waterway with gravel ? Help #17
$100...Wish I could have found it that cheap...Its more than double that around here.
   / filling in waterway with gravel ? Help #18
The city in my town is lay about 2 miles of culvert just down the street, maybe if they have any extra I could take it off thier hands, right.
Roger
Roger
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2023 John Deere 333G Track Loader (A53485)
2023 John Deere...
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
2001 John Deere M665 (A50120)
2001 John Deere...
