Filtering water from deep well (700 feet)
   / Filtering water from deep well (700 feet)
The filter cartridge will be as orange as a new Kubota in 3-4 months. :laughing:
Wow! I know what you mean, as we have another well that is 250' and very iron-y. It stains everything orange!
Thanks for sharing your experience!
   / Filtering water from deep well (700 feet) #12
The proof is in the plumbing - maybe - sort of?
Check the screens on your faucets/shower heads and see if there's any grit trapped in them.
May be scale from the water heater or sand from the well
   / Filtering water from deep well (700 feet) #13
Filtration is important even if test show it's not needed I would want at least a sediment filter and retest every few years.
What size expansion and treatment (kill) tanks did you put in?
   / Filtering water from deep well (700 feet) #14
We recently had a deep well drilled here in East Texas for our new home. It's drilled 700 feet deep and I think the pump is hung around 580'? I could be wrong there, I don't remember.
My well guy says I don't need to filter any of the water for sediment or contaminants, but he's also a classic East Texas "good ole' boy", ha!
The biggest concern I have when considering filtration is water flow. Our pump will do 15gpm feed from a 1.25" line into our 1" line at the house.
I have looked at the Aquasana Rhino system, as it seems to have all the parts I've been thinking we would need:
- Sediment filtration
- Contaminant filtration (carbon and copper-zinc filters)
- UV filtration
I've tasted the water and it's VERY good and clean. I'm waiting to get back the testing report from the well driller to see the report.
What do any of you use out there to filter a deep well, while still keeping good flow?
Thanks
I soften for but do not filter mine.. I dont have 'hard' water per say, but do have iron and iron bacteria (leaves the rust stains if not ran through the softener)
But, if the test comes back good, I would think the most you would need to do is a standard string-wound 'sediment' filter. No need to UV bugs that arent there :) Instead of using one large filter, I would split the line into 2 parallel ones and one use 2. You can run 2 of the standard 12gpm slightly smaller ones together, or better, 2 24gpm ones that are more than your flow rate and alternate. That way you can bypass one while changing filters and not have to shut off the water.
Heres a 4 filter system with 3 in parallel..
   / Filtering water from deep well (700 feet) #15
   / Filtering water from deep well (700 feet) #16
- UV filtration
Thanks
Get the water tested before investing in an expensive filtration system. YOu should be able to get a kit from your local health department. Cost won't be much. Water from that deep should be pretty well containment free.
Harry K
I haven't put anything like that in. My well guy basically told me that I could hook it right up to my home connection and let 'er buck!
Right now all I have in place is the well, pressure tank and mainline down to the house.
Thanks! This was the basic set up that I have had in mind - a parallel system for the sediment filters.
   / Filtering water from deep well (700 feet) #19
I use 5 micron string-wound filters for iron sediment. It is a simple in-out water flow. I change the filter about every 3 months. The whole filter unit costs around $40, the replacement elements run about $4-$6 each.
I don't notice any problem with flow which I think depends more on the pump than the depth of the well--assuming you have the correct pump for the well depth, adding a simple filter won't change much.
I would recommending the Big Blue canister with 10" x 4" filters.. I had the smaller filters and IF you have issues they clog up faster
I found that H2o Splash is a great place for housings and filters. I am currently using the 'washable' filters they sell.
Brian
   / Filtering water from deep well (700 feet) #20
Brian
Thanks for the tips. I collect such info like a squirrel collects nuts. :laughing:
I would say my filter is marginal for the amount of iron we have. No staining on fixtures or clothes, but definite orange coating in the toilet tank where it has a chance to settle out. So, I know some is getting through.
A while back, another poster recommended these too: Water purification, replacement filter cartridge, iron removal system, Fleck control valve
SUV (A59231)
SUV (A59231)
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A56858)
2012 Ford F-550...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2017 Ford F-150...
100cc Yamaha Dirtbike (A57453)
100cc Yamaha...
2017 Heartland Recreational Vehicles Bighorn Camper, VIN # 5SFBG4224HE340905 (A57453)
2017 Heartland...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
