Final drive out of my Bobcat 743
   / Final drive out of my Bobcat 743 #1
4440
Kentucky
JD 4440, JD 5303, JD 3038e, JD 250 skidsteer, Kubota L35, ASV 70, Bobcat 743
Well I spent the majority of yesterday and today disassembling my 743. The gear reduction on the right hand final drive finally went. The driven gear has two tapered bearings, basically both went. It had been grinding for some time and I knew it would finally fail. I just had put if off due to the amount of labor involved. So far I have removed the engine, muffler / oil cooler / radiator assy, pump assy, right hand final drive. Here are a few pictures from yesterday.
   / Final drive out of my Bobcat 743 #2
If you haven't bought your bearings yet, here's a link to a place I've been getting mine for the last year or so. MUCH more reasonable than a dealer price, and I've saved as much as 35% compared to places like Bearings Inc.
So far what I have gotten have been Timken U.S.A. bearings and cups. They sell bearing and matching cups in sets.
The downside is, is takes about 5 to 7 days to get them. Depends how bad you need the machine I guess.
Here is the link if you are interested.
JBR 17 LLC
Ended up ordering everything locally through a Bobcat dealership. Altogether there were two gears, two bearings, engine to pump coupler, brakes, and a few other parts. Total was almost $3400.
   / Final drive out of my Bobcat 743 #4
Yep, looks like most items are dealer items, and not much you can do about that. Bite the bullet, and move on..
Any idea what caused the bearing failure? Is there like a thrust nut and washer on the inside of the axle that wore?
Just be glad you can do your own repairs...!! I'd imagine the labor would have been as much, or more than the parts.
I had $900.00 in labor just replacing less than $30.00 worth of seals in the drive motors in my 450. That was after they put a new hyd. pump on it, thinking that was the problem with the hydraulics. The shop foreman did subtract the labor for the time spent on replacing the pump. And did knock off some on the price of the pump, because it did not fix the problem.
Since you have the price of the bearings on your invoice, you can still compare prices, at the site I sent you. Seems bearings are always going out on something....
We aquired this Bobcat about 5 yrs ago and it had around 1200 hrs showing. We ran the hour meter up to around 2800 hrs and it stopped working. So in more than likely if I had to guess, it has between 3500-4000 hrs on it. It has not give us any problems other than pins and bushings. It does have a little blow by but nothing I am concerned about. So more than likely the bearings were just flat wore out and as a result it wore the gears. I noticed the noise myself earlier this Summer and intended on fixing it sooner but never got the chance.
Got most of my parts and have reassembled and installed the right hand final drive gear box. Oh yeah, I had to replace the two universal joints in the engine coupling. Here are a few pictures.
coupling shots
couple comparison shots of old v/s new.
   / Final drive out of my Bobcat 743 #9
JBR 17 LLC
   / Final drive out of my Bobcat 743 #10
I went on the link did not bring me to tinkem bearings do you still have the bearing part no. For the bearing in the gear case thank you.
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
Compressor (A55973)
Compressor (A55973)
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
