finding parts or am I screwed
   / finding parts or am I screwed #31
CAN I BUY PARTS FOR THIS TRACTOR anywhere?
There are probably a lot of Yanmar 3T95W engines out there, all over the world. Just not in the US. So you need someone experienced in researching the world market.
I like Winston's answer:
Might also try https://www.allpartsstore.com/index.htm?customernumber=IL3226
Mr Sheaffer can get parts from Japan.
Leonard Sheaffer used to post here occasionally. Ordering parts from his contacts in Japan was his specialty. This is expensive, he has the cost of hours spent researching, and the cost of buying parts manuals that might be used only every year or so. So expect to pay a lot more than something that a dealer can identify in a moment.
I think for your F46D it will be worthwhile to engage a specialist like Sheaffer to find the parts you need. The parts are out there, its just that no one in the US has experience ordering them so you need someone who can do a worldwide search.
But first, try Fredricks. They may have imported this model before and have the parts manual to know what to order for you, even if they have to source your actual parts from overseas.
thanx California, I'll contact him the first of the week
   / finding parts or am I screwed #33
The John Deere 1250 (100% Yanmar) uses a 3T95 motor.Who knows if it's the same as a 3T95W,but might be a possibility.
Few parts available,but JD still has a .010 over rod bearing (CH20717) for $28.52 but that's all. Probably not big enough?
They have mains (CH20099) for $350-standard.
All States Ag Parts | Tractor Parts | Combine Parts | New, rebuilt, used | Online has a head gasket (CH16706) for $122
No rod available,so you will have to have it resized.
No crank available.You might have to have it welded up and turned down.
   / finding parts or am I screwed #34
I don't know whether the John Deere 1250 3t95w parts will fit your Yanmar or not but seems to be a pretty good availability of those parts. Listing only a few. If they are the same you can go to the John Deere parts page and get all the part numbers. John deere also has nice drawings you might compare.
head gaskt Head Gasket | John Deere | 1250 | Yanmar | 3T95 | CH16706 | 121850-01321 Head Gasket
Ring kit ch16933 Amazon.com : John Deere Original Equipment Piston Ring Kit #CH16933 : Patio, Lawn & Garden John Deere Piston Ring Kit - CH16933
Rod bearing ch20233 Amazon.com : John Deere Original Equipment Bearing #CH20233 : Patio, Lawn & Garden http://www.greenpartstore.com/John-Deere-Bearing--CH20233_p_112658.html
.010 rod bearing ch20717 http://www.greenfarmparts.com/John-Deere-Bearing-CH20717-p/ch20717.htm http://www.cwppartswarehouse.com/John-Deere-Bearing-CH20717-p/ch20717.htm
I am sure this could help you. http://southern-global.com/index.php?route=product/product&product_id=733
   / finding parts or am I screwed #35
My bet the 3T95 and the 3T95W is the same block. The US/JD models that I'm familiar with have the same Motor as the Imported model. For ex.My YM2000 Block is a T2R20A-A. I've seen T2R20A and just T2R20. When we bought the Ym2500 "Fred. Sup." it was told to us it was the same as the US/JD 850. The PTO gearing wasn't the same But the Eng. and Trans was. Good one Barry1 This Thread is getting better. :) My bet it's a JD. 1250. Eng. and prob.will bolt right up!!
You guys rock I'm seeing a light a the end of this tunnel, this is the info I been looking for and both Barry1 & winston1 came through < can't thank you enough for taking time to answer Dan
   / finding parts or am I screwed #37
If you get a good bearing and then take it to JD and see if it mic's out the same.
Per JD dealer they will send them out to a good machine shop and they will machine bearings to fit, they also have a place that rebuilds the clutch PP disk for 1/4 of what JD charge, I will keep you posted Dan
   / finding parts or am I screwed #39
i was wondering about just making bearings to fit. thinking it would not be that uncommon.
   / finding parts or am I screwed #40
Dan, thanks! Do keep us posted. Many of us JD and Yanmar owners are always looking for good resources.
Also, if you need a clutch PP disk, there are places online that sell them new or rebuilt. Still good to know. :)
White Metal Roof Panels (A55758)
White Metal Roof...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
1703 (A58375)
1703 (A58375)
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
2015 GMC Yukon XL SUV (A56859)
2015 GMC Yukon XL...
