Finish mower gear box used for auger
   / Finish mower gear box used for auger
I bought it mainly because it was $100. I have a zt and brush hog so it's not absolutely critical that I have it. It would be nice to have it because the tractor is more comfortable than the zt but I would still need the zt.
I thought this up yesterday when I was pissed. I figured it would be better than shooting it and making a fish structure in my pond with it. I will go up and take pics and put them on.
Ok here's some pics. One shows all that's left of the label.
Sent from my iPhone using TractorByNet
   / Finish mower gear box used for auger #13
Finish mower gearboxes typically are geared for an output speed of 1000 rpm, or at least all the ones I've seen do. One designed for a 540 rpm input has a gear ratio of 1:1.92 and one designed for a 1000 rpm input is a 1:1 gear ratio. You would NOT want to use that for a posthole digger as the auger would turn 5-10 times faster than you'd want.
   / Finish mower gear box used for auger #14
Walkin Horse,
Can you snap a pic with the belt threaded thru the pulleys as you had it? A wide shot which shows all the pulleys and idlers would be best.
   / Finish mower gear box used for auger #15
I suspect that this gear box is a 1:1 and uses the larger pulley to increase the spindle speeds. It would still be too fast for a phd imo.
Ok I will thread the belt back thru the pulleys. It's broke but I can still give you a good representation of if. It raining now so I will do it in the morning.
   / Finish mower gear box used for auger #17
Maybe you could sell it for $100. Like a fruit cake that nobody wants. Keeps making the rounds.
The amount of time I have wasted on it I would rather shoot it. But would the gearbox be worth $100 on C/L ?
   / Finish mower gear box used for auger #19
will wait for other pictures per what jenkinsph noted, but honestly, looks like deck is still in good shape, at least from top views, along with all the roller wheels / gauge wheels still all in good shape as well. as long as the deck is not completely rusted out, and all the spindles / pulleys rotated freely, and everything lined up correctly for the belt, it would be a nice finishing mower! i would pick it up the entire deck for 100 bucks maybe 180 bucks, if i lived near ya.
   / Finish mower gear box used for auger #20
Now that I looked at the pics it looks pretty decent. I would check that all spindles and pulleys are solid not vibrating or loose shafts. Make sure the blades are sharp and the belt has enough tension. Slipping belts build up a lot of heat in a hurry and then break. Check pulleys for anything that might be abrasive.
I would think this can be made to work.
Giyi Mini Auger (A53316)
Giyi Mini Auger...
2019 Ford Fusion Sedan (A55758)
2019 Ford Fusion...
2018 FORD F-350 (A55745)
2018 FORD F-350...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2018 Ford F-150...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
