Finish Mower in Rough Pasture
   / Finish Mower in Rough Pasture #1
FL_Cracker
Platinum Member
Palm City, FL & Blue Ridge, GA & Freedom, WY
Kubota L5030HST,R4 & Kubota RTV900R Utility Vehicle
I have a somewhat new pasture. It's still kind of rough and has lots of weed in with the grass. I'm looking at a new tractor and would like to purchase a larger finish mower. The pasture has lots of trees but I think I can work around them with a 7-8' finish mower. My Problem is I have three horses and don't want to cut the grass to low. Finish mowers see to set from 1-6" a ride on four wheels. If the pasture is rough will it fall in all these dips and dull the blades to fast? SHould I stick with a bush hog style rotary mower? I do have several field trails that I need to bush hog so I must purchase a 6' bush hog anyway?
Would the finish mower cut be to low to be good for the horses"
   / Finish Mower in Rough Pasture #2
From what I have seen a brush hog would seem the way to go. As to the horses, mine have always seemed to like shorter grass. Cows seem to like the tall stuff.
   / Finish Mower in Rough Pasture #3
Take a look at the Woods RM 990. It is a very heavily-built commercial finish mower with swing-back blades which are great if the field is rough. It is available with four castors so it floats independent of the tractor. I've had one for several years - it has made some pretty rouch fields look great. Cutting height is adjustable - mine is up around 7" at the moment and could go higher but that seems to clear most of my obstacles if I plan my moves. There is a review of it here The unit is a little pricey but for a rough field there is no other product I've seen that comes close. Woods blades are about $85 for the set of 6. Agri-supply has them for less. Hope this is useful.
Great info. Thanks alot. This will help a lot in my purchase....
Hope the tractor deal comes together soon. They just need to get my trade right.
/forums/images/graemlins/smile.gif
2016 HINO 195 16FT BOX TRUCK (A56129)
2016 HINO 195 16FT...
2022 Toro Workman 07921 Electric Utility Cart (A55851)
2022 Toro Workman...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
RIGID TOOLBOX (A52472)
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
