"finish" mowing with rotary cutter
   / "finish" mowing with rotary cutter #11
Re: \"finish\" mowing with rotary cutter
Sorry guys, but I have to be the naysayer.
I have a rear finish mower and just didn't use it. I just used a shredder to mow around my yard for about 10 years because it was hooked up and I did a LOT of other rough cutting. Once I brought the finish mower out of it's rusty retirement I was shocked to see how much nicer it made my mowed areas look. It just makes everywhere look manicured. I now use it exclusively on all entry/road/yard areas of my place. It makes me look like I know what I'm doing.
My finish mower only has 2 wheels and will scalp the grass in some areas. I saw a used finish mower the other day for half of the new price. It had four wheels and I think I'm going to buy it to see if it does a better job at not scalping. 2 finish mowers can't be too many, can it?
   / "finish" mowing with rotary cutter #12
   / "finish" mowing with rotary cutter #13
I have done the same. I only brush cut the rear of my property with a RC. I recently picked up a 5 ft KK finish mower with the anti-scalp roller. Was gonna sell it just to recoup some cash. I tried it one time just to see how it would do(on its highest wheel settings) and it was a noticable improvement over the RC. I may still sell it but now I don't really want to.
   / "finish" mowing with rotary cutter #14
I have no doubt a RFM will give a better cut. And either way the rocks have to go. Most of the acreage that I plan to just cut with the rotary cutter is at a reasonable distance from my house or driveway, but still in sight. The ground is pretty rough under all that grass, so it would be rough on a RFM (I'm assuming they aren't as tough as a med duty rotary cutter). I have a 4ft med duty cutter for the BX and have tested the cut on part of the property - not bad at all. The area to be mowed is too large for a 4ft cutter and the ground too rough for the BX (too rough on me!). Those small tires fall into every hole!
My plan is to get a larger tractor and large rotary cutter for other parts of the property and mow the acreage in sight, but away from the driveway and house. I really want to keep the BX and will if I can afford both tractors. I have a 5 ft MMM for the BX, so I can get a fine cut along the driveway and around the house with it. If I sell the BX later on, I will have funds for a RFM! /forums/images/graemlins/laugh.gif
Terry
Terry
   / "finish" mowing with rotary cutter #17
I've had great luck by sharpening my rotary cutter blade more like a lawnmower.. with a good edge, rather than like it should be fro brush.. which is like a 1/16 flat.
Soundguy
   / "finish" mowing with rotary cutter #18
Soundguy
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2018 HINO SA (A58214)
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
KBH 25T Tender (A56438)
KBH 25T Tender...
