Firewood Questions
   / Firewood Questions #81
First year I burned I made the mistake of splitting some smaller pieces of wood to start the fire with and put them in plastic totes with lids, opened them up to use them and there was mold/fungus everwhere. When I do split I usually leave it out in a pile for 2-3 weeks before stacking. Most of the time when I stack I use the sweedish dome method with a marker stick in the middle, when the wood shrinks to the level I have marked I know its good to burn.
   / Firewood Questions #82
LOTS of thoughts here.........If I have cut the wood this year, along about now, I put a tarp over the stack that overhangs the edge by a foot or so.......the stack may be 4' to 6' wide and 6' or a bit more tall and 30' long...........or I have one stack this year that is perhaps 15' wide 6' tall and 30' long.....just depends......
I always put stacks on old pallets..........
For kindling I typically buy a bag of fat wood at home depot or just pull spinters off of wood stacked outside the door and gather a few larger sticks from the yard..........
My wood stacks are perhaps 50 yards from the house down by a barn.....Perhaps once a week or every few days during burning season I load the RTV up and stack on the porch right outside the front door.......the stove is just inside the front door..........
God bless......Dennis
   / Firewood Questions #83
Ive been real lazy the past few years and Ive been using my 3 point wood splitter to make kindling. Man....that hatchet sure looks heavy :D
   / Firewood Questions #84
All I heat with is wood. I buy in the fall to burn a year later. I cover it with a tarp, but open on at least 1 side. I stack on 2x4 rails side by side. The snow makes it a pain to get. Usually I bring it in every day or every 2 days. I can burn 9-10" x 20-22". I don't split because it burns longer. A small cup of coals is more than enough to start a new fire. Basically the stove never goes out when the season begins. Watch out for carpenter ants in the wood you bring in.
   / Firewood Questions #85
If you do that, you can tailor the kindling to where you KNOW it will light, but you wonder if it might explode. :D
   / Firewood Questions #86
Experienced wood burners have tiny wood shop projects already drawn up on microfiche for the carpenter ants to construct. Why use plastic houses and hotels in your monopoly set when carpenters need work in the off season?
   / Firewood Questions #87
Perhaps the finest set of plans and photographs I've seen for wood stoves -to make yourself, -is that by a little known Italian company, Pimentos, and using the finest walnut. It even burns longer and hotter than the finest Scandinavian cast iron stoves, let alone the Vermont soapstone stoves! Unfortunately it is a one time deal, and rarely seen in action. The lustrous hand polished walnut glows with resins and fits any decor in any setting, certainly old world craftsmanship. I don't have the website- can anyone help me on this? Your friends and family will be amazed at the heat this heirloom wooden stove can put out!:D:D:D
   / Firewood Questions #88
EE Bota previously pointed out the issues one may encounter with carpenter ants. The main problem with the walnut sided wood stoves is that they attract fire ants. :laughing:
JN
   / Firewood Questions #89
We just got our wood in for the winter. We found a stand of standing dead fir up about 600' from the house. I cut and bucked and the girls pitched and rolled the rounds down to the splitter. We need 4 cords each winter.
This is as soon as we have ever got the wood in. Last year there was snow on the ground as we were cutting. We dropped a few trees for next winter up the mountain side north of the house, be nice if we have time to buck, split and stack early.
We have mostly Fir, some Pine.
   / Firewood Questions #90
I stack various hardwoods cut 14" - 16" in half cord layouts on scrap lumber on bricks. Each stack is under the shade (mostly) and covered (top only) by a tarp. The idea is to keep most moisture off but still allow air to circulate through. I try to age each pile at least 16 months but occasionally find a standing, long dead tree that lends well to immediate burning.
This year I plan to have no leftovers as Hurricane Irene, drought and road work has supplied me with about three new cords of red and white oak. The old must make way for the new.
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
