First day in seat of NH LB-115 TLB
   / First day in seat of NH LB-115 TLB #31
It's a BEAST !!!!!!!!!!!!
How wide is the rear bucket? I count 8 teeth on it, which is twice what I have on my 24 inch rear bucket.
I bet it will clear some land and keep a fire going real good!!
Thanks for the pics,
Eddie
   / First day in seat of NH LB-115 TLB #32
At last!.... Most impressive...
I want one now... :)
Thanks guys! Now I just have to hope she holds up a while before any significant repairs are necessary.
Eddie, I think that's the 36" in the picture. I'm putting in a rainwater retention system in those pictures so I needed to dig dirt and load stone fast-hence the 36" bucket.
The machine came with a 12" 18" 24" 30" 36" & 48" buckets, which is pretty amazing. He also included lots of extra teeth.
I don't see teeth like this around here-more like flat chisels. My Case buckets were more like spikes.
   / First day in seat of NH LB-115 TLB #34
Any new seat time?... Impressions?...
There's a 115 in TX calling my name... Probably pipe dream as I don't have time
to drive the one I have...
Impressions:
Backhoe: stupid power & reach on backhoe-even with a 3' bucket it just eats dirt. Wobble sticks work really nice with light touch-not as nice as the pilots in my Case, but they're fine-probably a lot cheaper to fix, too. Not too much slop in pins & bushings, just enough to make it a little scary. Foot pedal x-hoe works good, but sometimes it doesn't respond right away.
Powertrain: 4 wheel steer is a dream come true-it can manuever as good/better than my Case. Ground clearance with the 4 huge tires is really high-looks impossible to get stuck. Powershift transmission is really cool, but you can tell it's not quite as "hooked-up" as a shuttle shift. It feels like it needs to be revved more to move around the jobsite. There's 2 blinking lights ("T" & "N") that sometimes blink on the powershift lever that indicate a "fault" in the p/s trans. Manual says that this should be checked by NH mechanic, but seems to have no ill effect and is only sporadic. Manual says trans will go into limp mode if serious and it has never done that (knock on wood). Brakes work good, but are pretty close to the floor-previous owner said they've always been like that.
FEL- huge sucker. Must be 1.8 yds. Fills my 11 yard dump truck body in 5-6 scoops! Here's the unknown secret of the LB115-even with the loader bucket FULL and raised up high, the machine feels incredibly stable. The large front tires are the reason-the machine doesn't "wobble" like my Case did when raising a full bucket up into the dumptruck. 4/1 bucket works good, but as I thought, a little hard to see over big tires in front.
CAB- fantastic, roomy industrial grade cab that feels like a real serious work station with great visibility. You feel like you're in a quarry loader. Doors & floor are VERY solid and not rusted at all. Seat is a high back air ride with compressor & lots of adjustments. Floor mat is beefy & looks like new. Controls are more like an '09 machine instead of an '00 machine-very modern and well laid out. Tons of storage bins, tinted glass and adjustments for vents, seat, tilt wheel, etc.. I like the way the back window slides up above your head instead of 3 sliding windows in Case. Some switches have light bulbs burned out and you can't tell if they're off or on. Digital gauges appear accurate, but previous owner installed mechanical hour meter and mechanical oil pressure just in case-very cool. Radio is very nice and has a flip down dust cover to keep controls sealed from dust. Fenders are plastic, but in great shape and of course-no rust anywhere to be found. Paint almost 98% in tact. Haven't had the opportunity to hook up rear aux hydraulics yet.
OTHER: Got 5 backhoe buckets and a sheepsfoot. Only used 3 of the buckets so far. All are "Gannon" brand. FEL bucket is in great shape. Paint on this machine is incredible. For 10 years old, it looks like it's a 3 yr old paint job. Puts Case paint job to shame.
BAD: Cab leaks in heavy rain (My Case leaked, too). Looked up top and cut outs for beacon lights have cracked & opened-up and allow water in the roof. Roof is kinda chincy-thinner plastic than I'd like to see and lots of unsealed fasteners holding it down to cab. I'll have to add the beacons or seal the holes better. Would like to buy new roof and make it right. Powershift trans looks like a high-tech nightmare when it goes down, but is pretty nice to drive around. Fuel tank claims to be only 28 gallons, but seems a lot bigger. Case had 50 gallon tank. Harder to see FEL than Case because of big front tires. Sits 16" higher than Case, so harder to get in/out.
All in all I think I got very lucky. Previous owner was hard core excavator and bought machine new. Maintained as good as I could possibly ask for. Never smoked in or abused. I will only use it 5-10 hours per week, so it should be Ok in it's new "semi-retired" life. I hope it holds up a few thousand more hours for me.
   / First day in seat of NH LB-115 TLB #36
Builder,
Excellent review. Easy to read and very informative. I never thought about the stability improvement with the larger tires, but know what you mean about it with the smaller tires. When loading on uneven terrain, I keep my bucket low until I'm ready to dump it, then I raise it up and over the bed.
What is involved in swapping buckets? Do you have some sort of quick attach? or are you pulling pins and lining it all up, then putting the pins back in?
One of the things that I've found really annoying with New Holland, the company, is that they are trying to change some of their components to be the same with Case. They went from $40 for a cylinder piston, to $200 for the upgraded one that is also used in the Case cylinder. I wasn't happy about this, but luckily the parts guy told me about a local guy who specializes in hydraulics and will sell me just what I need and not a kit that works in a variety of tractors for five times the money.
Eddie
Builder,
It surprised me, too Eddie. I can't believe how much the stiffer, bigger rear tires make the FEL feel more stable.
Yep, I'm doing the buckets the old, manual way. It's not too bad, but I'd love a manual quick coupler. I wondered if that would make my 5 buckets unuseable, or there's a way to still use them if I got a manual coupler.
Eddie
I've heard that, too. NH parts seem to be bargain priced compared to Case or CAT.
I went to buy cab outside mirrors for my Case and they were $520 a piece!!! :eek::eek::rolleyes:
I just bought mirrors for my NH and they were $60 a piece. Not as nice, but $520??? :rolleyes:
   / First day in seat of NH LB-115 TLB #38
The cylinder seal kits are a mystery... The ones for my old 580D are around $20 a set...
Probably has to do with the fact it's an '81-'82 model...
Excellent review Builder...
'nudder thing I like is the way the backhoe locks for transportation. I hated the way my Case was done. Seemed like a system from the 1950's. The NH you just pull the dipperstick back and push a button. A horseshoe-like locking ring grabs the dipperstick and locks it.
My Case felt like it would smash the cab glass or your face everytime I locked the dipper.:eek:
   / First day in seat of NH LB-115 TLB #40
My hoe has what sounds like the same locking device. Mine is a 1998 555E. My neighbor wanted to buy a brand new Case backhoe with a cab, 4x4 and 4 in 1 bucket. They wouldn't deal with him at all, said it's this much, take it or leave it. He left and went to New Holland, who gave him a fantastic deal on financing, extended warrantee and price. It's about two years old, maybe three years old. Anyway, he saw how mine hoe locks into place and told me that his is different. He paid $70,000 for a backhoe that he hates how the hoe locks into place and wished that it was like mine. I never checked on his when he's been around, so I don't know what they did differently, but for whatever reason, it sounds like New Holland changed it.
Eddie
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
Deere 350G LC (A53317)
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
CATERPILLAR D8T CRAWLER DOZER (A52707)
CATERPILLAR D8T...
