Jim57
Veteran Member
- Joined
- Jul 26, 2005
- Messages
- 1,295
- Location
- South Carolina, Westminster - USA
- Tractor
- Shibaura SD2200 4X4
Notice the Valve Boxes that the Control Valves are Located in.
Cliff_Johns said:I guess this means you aren't going to use your tractor in this area anymore, is that right? It looks like there are PVC pipes burried in the whole perimiter, and I would think you would break them easily with a CUT or other heavy vehicle.
Cliff
Egon said:Looking good Jim.![]()
Jim57 said:I have worked long hard hours and came up with tons of money to get this operation in motion.
jinman said:I don't see how you can go wrong, Jim. Last year you produced very well for that little spot and with the irrigation, you surely will have good luck and less hands-on. Now you can concentrate on crop rotation in the different plots and prevention of insect and disease damage. Those require a watchful eye and quick attention before they get out of hand.
I'm looking forward to seeing your progress. I may not post much, but you can bet I'm "lookin' over your shoulder."![]()
Egon said:Look at light house pictures. Then take your pick on what seems to suit you.
Of course I'd suggest an electrical light source rather than the older type mantle Lamps.![]()
To elimate the threat of breaking irrigation pipes; use wet sand for nearly 100% compaction.Jim57 said:Actually the PVC pipes are in the areas I won't be tilling. They are also in the ground about 12 to 18 inches. They are in the grassways and water ways that control erosion. I have already gotten the area plowed and had my truck in there without incident. Seems to be a good plan. The only thing I am concerned with is maybe some rock getting against the pipe and causing a rupture. However... repairing PVC is a piece of cake.
Just wait until you see the results. The irrigation made the soil much easier to work. Having the right moisture content in the soil does wonders and is easier on the tractor while cultivating and plowing.
Jim
