YOTI
Mr. Bonham, I know the Lord will bless you for this project and following His leading. I thank you for the example you have set.Jim57 said:We also installed 5 of these Hydrants that are live all the time for spot watering and washing vegitables as they are harvested.
One suggestion for the hydrants, from experience. I would sink a treated 4x4 beside them and strap clamp the hydrants to the posts. They have a much better chance of surviving a collision whether it be the tractor or wheelbarrow. Even an impact small enough to slightly move the hydrant will in some cases be enough to crack a pvc fitting and since they are live lines end up in a leak. A big enough impact would mean gyser time! Another idea might be a cut off upstream of the hydrants in case of a break, that way you would only loose the hydrants and not the whole system if you had to shut it down for repairs.
Thanks again for your efforts and Blessings on ya, Craig
