First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres
My Hole King Post Hole Digger I purchased a week or so ago. I need to build a stand for it to make it easier to put on and take off. Has anyone done this? Could be another little project for me.
Jim
This is suppose to be a 4 ft King Kutter Bush Hog... I'm not sure. It works well except the four bolts that hold the gear box on has worked loose. I can't seem to get them tightened.
Another view of Bush Hog
Hear is a close up of bolts I am speaking of. Anyone have the tools to fit these. I understand the blades and stump jumper has to be taken off to do this. The large nuts and bolts that hold blades and stump jumper on are huge. I don't have the tools large enough to do this job /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/crazy.gif
We have been blessed finding some equipment to use with the tractor at reasonably cheap prices. So far we have 10 pieces of equipment. The only one I do not use so far is the Box Scrape. I guess I threw my money away on this equipment. It's not really useful so far to me. I need an areator, fertilize spreader, sprayer and a manure spreader much worse.
Anyone up for a trade?
Jim
Jim
   / First Serious Project - Clearing 1.5 Acres #880
</font><font color="blue" class="small">( This is suppose to be a 4 ft King Kutter Bush Hog... I'm not sure. It works well except the four bolts that hold the gear box on has worked loose. I can't seem to get them tightened. )</font>
Hi Jim,
If you cant get those bolts tightened up with some help, and cant get them off /forums/images/graemlins/confused.gif, your going to have to cut them off ! Then install new bolts and locknuts. If that condition remains like that the gearbox will be damaged, elongated holes or cracked casting /forums/images/graemlins/frown.gif
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
flooring (A55758)
flooring (A55758)
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2000 JLG 800A TELESCOPIC/SCISSOR BOOM LIFT (A52709)
2000 JLG 800A...
2284 (A58376)
2284 (A58376)
