First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres #881
</font><font color="blue" class="small">( This is suppose to be a 4 ft King Kutter Bush Hog... I'm not sure. It works well except the four bolts that hold the gear box on has worked loose. I can't seem to get them tightened. )</font>
Hi Jim,
If you cant get those bolts tightened up with some help, and cant get them off /forums/images/graemlins/confused.gif, your going to have to cut them off ! Then install new bolts and locknuts. If that condition remains like that the gearbox will be damaged, elongated holes or cracked casting /forums/images/graemlins/frown.gif
</font><font color="blue" class="small">( ( This is suppose to be a 4 ft King Kutter Bush Hog... I'm not sure. It works well except the four bolts that hold the gear box on has worked loose. I can't seem to get them tightened. ) )
(Hi Jim,
If you cant get those bolts tightened up with some help, and cant get them off /forums/images/graemlins/confused.gif, your going to have to cut them off ! Then install new bolts and locknuts. If that condition remains like that the gearbox will be damaged, elongated holes or cracked casting /forums/images/graemlins/frown.gif )</font>
I know Scotty. What I was saying is I do not have wrenches big enough to do the job. I guess I will have to load it up and take it to someone that has the proper tools to fix this problem. I hope it hasn't done very much damage. I haven't used it but very little since I found it. I have no ideal how long it has been loose. I don't think it has been long though.
(Hi Jim,
Ok Guys... I found an Antique Truck today and purchased it. It was made November or 1975... making it a 1976 Chevy Custom 10 Shortbed Pickup. 350 V-8 with AC and automatic transmission. Here is a couple of pictures I took tonight to show you. I will take more in the daylight tomorrow.
Do I hear an offer?
Jim
Do I hear an offer?
Jim
</font><font color="blue" class="small">( Ok Guys... I found an Antique Truck today and purchased it. It was made November or 1975... making it a 1976 Chevy Custom 10 Shortbed Pickup. 350 V-8 with AC and automatic transmission. Here is a couple of pictures I took tonight to show you. I will take more in the daylight tomorrow.
Do I hear an offer?
)</font>
This is the other side. I will take pictures of all of it tomorrow. For it to be 30 years old... It's in Great Shape and runs very good. It has new tires and all the chrome, center caps and beauty rims are in good shape. It has all body chrome in good condition and it has dual exhaust as well.
Do I hear an offer?
)</font>
   / First Serious Project - Clearing 1.5 Acres #888
Just don't take it out on salty roads. Those models had a tendency to rust out from under you.
Has A/c been converted to the new fluids?
Egon /forums/images/graemlins/grin.gif
   / First Serious Project - Clearing 1.5 Acres #889
   / First Serious Project - Clearing 1.5 Acres #890
</font><font color="blue" class="small">( My Hole King Post Hole Digger I purchased a week or so ago. I need to build a stand for it to make it easier to put on and take off. Has anyone done this? Could be another little project for me.
)</font>
Jim,
Do you have a low hanging branch on a tree to hang it from? I put a chain around the tube by the gear box and hang it from there. It's almost impossible to hook mine up by my self if it's on the ground.
Dave
Kohler 200R0ZD81 Power System 200 Generator (A55787)
Kohler 200R0ZD81...
2003 Chevrolet Silverado (A53314)
2003 Chevrolet...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A55788)
2019 Ford F-550...
HD4  3' Blade Brush Cutter (A53316)
HD4 3' Blade...
