Tractordawg
Bronze Member
I would go with the L3130 to remove the snow from your 1/4 mile long driveway. I know sometimes you have to move the snow before you can get out to go to work in the morning. The L will make much quicker work of this.
This alone may limit your choice on tractor size. Getting into a stall with a B or L tractor may be impossible unless your stalls are very large.
newbury,
As someone who is strongly considering a BX, what situations have you found the BX to underperform due to ground clearance?
gdh
If your lawns are rough, you might appreciate the larger rear tires of a B-series. The smaller BX rears can give you a rough ride over the bumps. Having to slow down to keep from being bounced around may not be the best use of the tractor's capability. The B7610 is fine on my rough lawns, but I didn't enjoy the jostling it gave me on an even rougher hayfield.
It may go in your garage ....but it may do this to your garage.Sounds like a great package and I am sure you will enjoy it.
A couple minor tips:
1. The tractor won't go in a normal height garage door with the ROPs fully up. I don't know about the canapy, but just in your excitement don't run it into the garage door.
2. That 7' blade will be great for clearing snow off the driveway. But keep in mind when you get near something such as your house that it is sticking out beyond the tires so you don't catch it on something.
3. There is a float function with the FEL that alows it to ride along the surface without putting much down force. It is not very well explained in the FEL manual. To get it into float, push the FEL control level forward as if to lower it, then give it an extra little push. You will feel a click and the bucket will continue to lower to the surface. Level the bucket with the surface and it is very helpful feature for removing snow from concrete surface or clearing drifts or piled up snow.
4. The Pat's quick disconnects for the 3pt hitch which are advertised on this site are very helpful in removing and replacing hitches.
Enjoy the ride.
It may go in your garage ....but it may do this to your garage.Congratulations on your purchase!
Now it's time to get working (really playing) and reduce my to do list!
My tractors garage and upstairs is the Babies Playhouse.Is that your garage ?! :laughing:
