Tiller Five-foot Tiller with Ford NAA
   / Five-foot Tiller with Ford NAA #21
Found this.
Its specs gave rpms at 540rpm. That's a familiar number.
   / Five-foot Tiller with Ford NAA #22
Is there the opposite of a gear reducer that would allow you to get your PTO speed for implements while having a lower rpm on the tractor?
Or could a gear reducer be installed backwards?
so far 2 of us have mentioned HOW you go about using a tiller on an old ford. you get a howard post tranny.
as far back as post #5 that was mentioned.
   / Five-foot Tiller with Ford NAA #23
I have a 1954 NAA. A tiller behind it does not work well. The PTO on this old Ford is not a live PTO. By the time you get the PTO up to the proper speed for your rear attachment the ground speed of the tractor is to fast for the attachment to work correctly. I have the same issue with a 3 point snow blower. I have a 5' King Kutter brush cutter and that works well, although I have an over-run clutch on the tractor's PTO.
has nothing to do with live pto or not live pto... has to do with ground speed vs pto speed and engine rpm... fords before the 8spd and the 10spd have TALL gears... not great for tillers without aux post trans help.
   / Five-foot Tiller with Ford NAA #24
if it was already plowed and disked it would probably work ok to smooth out and fluff up the soil real quick, but like other have said the ground speed would be way to high for the tiller to dig in under normal conditions.
   / Five-foot Tiller with Ford NAA #25
I would think a HST is better for tilling because of the variable speed ability.
I certainly think a tractor with HST is much better for tilling. The infinite ground speed makes it much easier to work implements that use the PTO, especially if the horsepower you have is a bit under or border line for the task and equipment.
   / Five-foot Tiller with Ford NAA #26
Are the Howard gear reduction units expensive? General or average sale price? Do they still make them?
Thanks- Oldstuff
   / Five-foot Tiller with Ford NAA #27
:) havn't made them since them tractors were out.
they are considered rare.
i have seen them go for 1000$ and a hair cheaper too.
   / Five-foot Tiller with Ford NAA #28
Thanks,
Oldstuff
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
Kawasaki NR (A50324)
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
CHAMPION C80C MOTOR GRADER (A52707)
CHAMPION C80C...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55314)
Kuhns AE10 Small...
