flail mowing
/ flail mowing #1
naturalemu
long 610
are flail mowers good for clearing and mulching under growth ? If so how big of trees will it work on ?
/ flail mowing #3
Perhaps you may receive more replies by posting in the "Attachment" forum here on TBN. In regards to your question, it largely depends on the size of mower you are looking at, plus the PTO rating of your Tractor. Most mowers have the specs in relation to their cutting capacity; included in the manual. If you are looking at a used one, just Google the manufacturer, make and model and you should find the answers. BTW, welcome aboard. :tractor:
/ flail mowing #4
Seems to be a LOT of variables to that questions, but there is a LOT of info on here. If you have not had a chance do a search for "Flail", or "Flail mowers" and you will be able to read for days!
I recently bought one and have since learned that there are several different types of "knives" or "blades" and each have their uses. I personally have kept my brush hog for the BIG stuff but plan on using my flail around the neighbors, roadside, and the field areas. I will run the hog is the woods where I am knocking down 2+" stuff and don't care if I throw something out from under the deck.
3pt 4' Dirt Scoop (A64119)
3pt 4' Dirt Scoop...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
IRONCRAFT 2515 BATWING ROTARY MOWER (A64280)
IRONCRAFT 2515...
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2005 Freightliner M2 106 Ambulance (A61573)
2005 Freightliner...
