flat faced quick disconnects issues
/ flat faced quick disconnects issues #1
Rio_Grande
Platinum Member
Have any of u had problems with these lasting? I am on my second set now. first set i just plugged in and went, second set I cleaned every time I used them, Even kept a rag in the skid steer to do it.
The first set just started leaking and wouldnt stop. This time it is the female coupler and it will not lock onto the male without smacking it with a block of wood, which at the cost of the components is not acceptable. There dosent seem to be way to service or clean these. At 80.00 for the female connector I am starting not to like these.
Anyone have any other experience with them or advice on how to get them to last?
/ flat faced quick disconnects issues #2
First of all, why are you paying $80 just for the female connector? Are you using a larger than normal size? ISO 16028 flat face couplers with 1/2" (nominal size) bodies, the most common size, are readily available for about $50 per set.
We sell at least a dozen sets a week here, and we haven't seen any more problems with these than with any other couplers.
Our most common complaint with any coupler has been "they leak" and almost every time, the leak disappears as soon as we flush them out on our pressuring testing equipment.
/ flat faced quick disconnects issues #3
Some of the manufactures off rebuild kits for the QD's. That does seem kind of steep for the flat face connectors. Some people also go the next larger size to compensate for the reduction in flow. If you shop around, you can fine them with a great price difference. Did you particular want flat face QD's? Yes, they are easier to keep clean, and no, they all do not all connect under pressure.
After reading this thread I did a bit of pricing around and you are right I was getting hosed.
I never could find them anywhere but my local hydro shop. Called the company who sold me my skid steer and they had them for 30ish for the female connector.
Seriously the hydro shop down the road from mom and dads hit me for 80.00 pluss some tax for one female connector little over a year ago. We were broke down because of the fitting and I had to do something.
I had seen them on ebay cheap but figured they were not as good as the last one I had bought. Glad my dealer has them and takes care of us.
I am sure the hydro shop has a flow tester but what are they gonna charge to put it on.
I didnt especially want this style connector but it is what my loader uses.
/ flat faced quick disconnects issues #6
Just as an FYI, I probably sell more flat face quick disconnects on eBay than any other seller. Chances are the listing you saw there was one of mine. -laughs-
/ flat faced quick disconnects issues #7
We use them at work and are not impressed. We have seen these be bad right out of the box - brand new. On more than one occasion we have seen them go bad on the return line which blocked the flow and promptly blew the seals out of the valve we use in our equipment. On a couple of instances it bent the spools in the valve. The old round ball fittings were cheaper and lasted much longer. I highly recommend changing out to those.
Justin
/ flat faced quick disconnects issues #8
Listen to Hydraulic Hose Guy. He is right on. I have had the exact same experience except I can't come close to his price.
Not meaning any disrespect there is just alot of cheap crap out there and alot of it is on ebay. Can us send me a link to one of yours? I like buying off of stand up folks. Gonna need spares just in case this one goes out.
Jeff
/ flat faced quick disconnects issues #11
I am surprised people are having problems with flat faced connectors. I switch everything over to them when I can. They are easy to keep clean and no fluid loss when connecting/disconnecting.
Ken
/ flat faced quick disconnects issues #12
That would be great except my $35,000 machine has them built in. I could tear all that out, but I am not ready to start that kind of mods to this machine.
It all depends on whether you like the setup or not.
If it is not broke, don't fix it. Those female fittings cost about $78.00.
The male counter part is a 8010 male coupler.
However, you can't go wrong with a set of $13. couplers, as spares.
https://www.surpluscenter.com/item.asp?item=9-7241
Parker - 8010 NIPPLES (ISO 5675) - NA
/ flat faced quick disconnects issues #13
Not sure what brand couplers you are using but I do know that we have some Snap-tite 78 series at work that if disconnected with some trapped pressure the nipple will fail to close almost every time. This cuts the seals and I have never been able to get one apart and back together yet.
When connected I have never had an issue with flow closing them and we have run 30+ GPM though #8 SAE size.
/ flat faced quick disconnects issues #14
Jeff
No disrespect seen here, Jeff. Here are a couple of listings we have up currently for flat-face couplers. Click on our store link if you'd like to see more.
(4 sets) 1/2" Skid-Steer Hydraulic Hose Quick Couplers - eBay (item 220491215579 end time Dec-30-10 13:35:56 PST)
(1 set) Skidsteer Flat Face Quick Disconnect Couplers - eBay (item 380296575613 end time Jan-05-11 11:25:29 PST)
/ flat faced quick disconnects issues #15
78 Series? That's a wing-nut design (aka "Wet Line Coupler"). It's a completely different animal from what we've been discussing here. One of the advantages of this design is the ability to connect under pressure.
/ flat faced quick disconnects issues #16
Duhhhh, meant the 71 series. Just ordered some -24 SAE 78 series for high flow and that number stuck in my head.
thanks for catching that,don't want to intentionally mislead people.
/ flat faced quick disconnects issues #17
I agree with the trapped pressure theory. It's disastrous on some of those couplers.
Figured out Hydraulic Hose guy I do have some of your Ends, I bought them from you for the tractor side of my setiup before we laid out the money for the MTL. Come to think of It we have had them on there for about 3 ish years without a problem. I need to get a couple sets from you for backups. After replacing this one on the bucket side we are not having any issues. After looking at the old one it is a Parker and it appears something broke internaly as all the guts are pushing out of it. I pitched it in the junk pile.
Thanks again for all the info.
/ flat faced quick disconnects issues #19
Are these Connect under residual pressure rated? Do they come in 1/4 " and 1/2" sizes for NPT threads?
/ flat faced quick disconnects issues #20
The couplers we list on eBay do not connect under pressure. We do have on our website, a connect-under-pressure male coupler, and a connect-under-pressure female coupler. See links below.
http://www.discounthydraulichose.com...t_p/ht-cup.htm
Please note: you cannot connect with both couplers under pressure. In order for either of these couplers to connect under pressure, they must be joined with a compatible mate that is NOT under pressure.
King Kutter II Tiller for sale.
King Kutter II...
Outdoor fireplace (A64557)
Outdoor fireplace...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
