Phillip w
Platinum Member
- Joined
- Jun 21, 2017
- Messages
- 777
- Location
- whiting ks
- Tractor
- allis Chalmers 185 and massey ferguson 1531
Recently I had a flat tire on the rear of my tractor and didn't realize it until it was broke of the rim. What a mess trying to air it up. I found a remedy that. Seems pretty effective. I used the loader on my big tractor to raise the little tractor on two wheels. (A Jack will work to raise the flat tire off the ground) Next I took some dish soap (say dawn or ajax) and squirted the soap around the rim and tire bead. Then I took a couple pieces of chain and rapped them around the center circumference of the tire. Using two chain tighteners/boomers I drew the chains around the tire down as tighat as I could. Making sure I had at least 100 psi in my air compressor I began airing up the flat tire. As I was airing the tire up and it was wanting to air up yet still leak, I began to strike the tire with a 2 pound ball peen hammer. The tire began to seal and air up. The just release and remove the chain and tighteners, lower the tractor and you good to go. Seems like.a pretty effective method to me.
