1stDeuce
Of course, you gotta get some real air into it ASAP, as the hot stuff will start to condense, and possibly even let the bead pop off.
Pull the valve core. That way as it's cooling, it'll just suck in air, instead of pulling the bead back off... Also helps keep from damaging the tire if you happen to use a little too much starting fluid.
And with no core, the tire will air up about 10x faster... I run it up to the desired pressure or a little higher, which only takes a few seconds, then jam the core in and tighten it, and then adjust the pressure to suit. Way faster than airing up from zero with the core in... Just don't loose the core while you're trying to jam it in as air is rushing out!
FWIW, I've never gotten WD40 to work for this, only good starting fluid. I have some cheap starting fluid that just burns like WD40... I just use that can for starting stuff.
