beaglebriar
If you don't mind me jumping in on here, I am looking to attach a Rhino 75C backhoe to my Ford 1900 (1981), It comes with a supframe but it says it will fit NH TC30, 40 and 50's. I will probaly need to make a bracket or two. But i am stuck as to where the attachments for the front goes and for the rear. Plus the hydraulics I am a little stumped on.
Pictures/ measurements of the backhoe subframe will be a big help. It will also make a difference if you have a loader or not. You should be able to track down a schematic of your hydraulic system and that should help you figure out supply and return. I think you could hook to the lower 3pt pins in the rear and fabricate a couple brackets for the front easy enough. The flat frame rails in the front would probably work great if the subframe is long enough.
