Ford 1620 Deal or No-Deal??
   / Ford 1620 Deal or No-Deal?? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
No, you did'nt see this post somewhere else. You're just imagining things...
I'm working on a deal (another one) with a local dealer. He has a Ford 1620
hydro 4X4, turfs, 1300 hrs. He is willing to take a 7108 loader off a 1320 and put it
on this tractor for me. The tractor looks like it has spent some time stored
outdoors. It's a 1993 and has the bumps and scratches you would expect. The
front tires need to be replaced but the rears are excellent. He threw out a price
off the top of his head of $12,500. The tractor needs some paint touchup, some
bulbs replaced, and a good cleaning and degreasing of some parts. I don't think
$12,500 is a good price for this machine. He said he would work on the price and call me tomorrow.
What is a good price?
Does anyone know the 3pt hitch capacity?
Does anyone know the hydraulic flow rate?
Dealer says 27 hp. Is this correct?
Is a 7108 the right loader for this machine?
Jerry
   / Ford 1620 Deal or No-Deal?? #2
for this price I think I would go with a new TC30 same tractor not much more money and a warranty!
   / Ford 1620 Deal or No-Deal?? #3
<font color=blue> Dealer says 27 hp. Is this correct?</font color=blue>
Unfortunately, I don't have the specs for the 1620, but I do have a brochure that lists the 1720 as being 27.7 gross engine HP (23.5 PTO HP). I would bet the 1620 is somewhat less.
I didn't know hydro trans was an option on the 1620. I thought all you could get was the standard 12/4 or the optional 12/12 shuttle shift.
John_Mc
John, I have found that getting info on Fords and New Hollands can be challenging. From what I have been told......The 1620 is the hydro version of the 1720. I was told that everything else is the same. Assuming that this is true (until informed otherwise), do you have any other specs? 3pt hitch, hyd flow, engine displacement, total weight. I am truly starved for information on this tractor. Any help is appreciated.
Jerry
   / Ford 1620 Deal or No-Deal?? #5
Jerry,
I copied this from the Tractor data website.
<A target="_blank" HREF=http://www.tractordata.com/>http://www.tractordata.com/</A>
Ford-New Holland
1620
Manufactured: 1992 - 1997
Cost: $17,000 (1997)
Horsepower:
Engine: 27
PTO: 22
Engine:
Fuel: diesel
Cylinders: 3
Displacement: 81.1
Manufacturer: Shibaura
Transmission:
Forward: infinite
Reverse: infinite
Capacity (Gal):
Fuel: 7.1
3-Point:
Category: I
Power Take Off (PTO):
Type: live
Speed (RPM): 540
Tires:
Front: 5.00-15
Rear: 9.5-24
Weight: 2,250 lbs
Serial Numbers:
Spencer, the TC30 implement flow rate is 6 gpm and 3.5 gpm for steering. I was thinking that maybe the 1620 has more flow than this??? So, whats a good price on a TC30?? I was quoted $16,300 with R4's, hydro, and loader.
Jerry
   / Ford 1620 Deal or No-Deal?? #7
This comes from the All Makes Tractor tips website
http://www.tractortips.com/make_model/specsdisplay.asp
Tractor Specification
Make: FORD Model: 1620
FWD/REV Standard: Hitch Lift: 1637
FWD/REV Optional: Hydraulics-Type: OPEN
Years Made: 1992-1997 MFWD-STD/OPT: OPT HYD-CAP: 7.1
HP-PTO: 22 Tires_SD/OPT: 5.00-15 Tires-STD Front: 10.0
HP-Engine: 27 Tires-STD Rear: 9.5-24 HVD Std Outlets: OPT
HP-Drawbar: Wheelbase - Inch: 63.0 Cooling Capacity:
Engine-Make: SHIBAURA PTO Type: LIVE Fuel Tank Capacity: 7.1
Engine-Fuel: DIESEL PTO Speed: 540 Cab-Std A/C, ROPS:
Engine-CYL(s)-CID: 3/81.1 3PT Hitch CAT I: Yes Weight: 2233
Transmission-STD: HYDRO 3PT Hitch CAT II: No New Price: $16,701.00
Optional: 3PT Hitch CAT III: No
   / Ford 1620 Deal or No-Deal?? #8
1993 Ford 1620 ($7,500)
1300 hrs, w/loader, 60" bucket, 13.6 x 16 turf tires
KROMMINGA
MOTORS Phone
(319)465-5443
19415 Hwy. 151 South
Monticello, IA 52310
FAX
(319)465-4688
NEW HOLLAND
Open 7:30 until 5:00 Monday through Friday, Saturday until Noon
Email Address:
krommingamotors@n-connect.net
__________________________
DETAILS for TRACTORS from FORD
Model = 1620 4WD COMPACT
SPECIFICATIONS
Years Mfg: 1992-1996
Fuel: D
Engine Make: SHIBAURA 3-CYL
CID: 81.1
Engine HP: 22 PTO
27.3-E
Cab: ROPS
No.Speeds: HYDRO
Weight(Pounds): 2,352
List Price: $14,705
PRICING
Year Ad Price Est.Loan Value
1992 $8,529 $5,629
1993 $8,970 $5,920
1994 $9,411 $6,211
1995 $10,146 $6,696
1996 $10,441 $6,891
Wow, John Miller, your info (as usual) is a real show stopper. You must work for the government or something.
Seriously, thanks, I think I will be looking for a better deal. I know my dealer won't come down that low. I saw one of these sell on Ebay two weeks ago for $8,500. Seems like the $7,500 to $8,500 is the right price range.
Thanks to everyone who responded. You guys really came through on this one.
Jerry
   / Ford 1620 Deal or No-Deal?? #10
I had a deal on a 1993 Ford 1620, semi new turf tires, with 2,300 hrs, new FEL, 72" MMM for total price of $9,250, just to give you a comparison. Didn't buy it because the MMM did not leave any clearance at its highest position (less than 3"). Also thought it was a little big for my needs. The tractor was $6,500 and the FEL was $2,750.
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
