Ford 1620 Deal or No-Deal??
   / Ford 1620 Deal or No-Deal?? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
No, you did'nt see this post somewhere else. You're just imagining things...
I'm working on a deal (another one) with a local dealer. He has a Ford 1620
hydro 4X4, turfs, 1300 hrs. He is willing to take a 7108 loader off a 1320 and put it
on this tractor for me. The tractor looks like it has spent some time stored
outdoors. It's a 1993 and has the bumps and scratches you would expect. The
front tires need to be replaced but the rears are excellent. He threw out a price
off the top of his head of $12,500. The tractor needs some paint touchup, some
bulbs replaced, and a good cleaning and degreasing of some parts. I don't think
$12,500 is a good price for this machine. He said he would work on the price and call me tomorrow.
What is a good price?
Does anyone know the 3pt hitch capacity?
Does anyone know the hydraulic flow rate?
Dealer says 27 hp. Is this correct?
Is a 7108 the right loader for this machine?
Jerry
   / Ford 1620 Deal or No-Deal?? #2
for this price I think I would go with a new TC30 same tractor not much more money and a warranty!
   / Ford 1620 Deal or No-Deal?? #3
<font color=blue> Dealer says 27 hp. Is this correct?</font color=blue>
Unfortunately, I don't have the specs for the 1620, but I do have a brochure that lists the 1720 as being 27.7 gross engine HP (23.5 PTO HP). I would bet the 1620 is somewhat less.
I didn't know hydro trans was an option on the 1620. I thought all you could get was the standard 12/4 or the optional 12/12 shuttle shift.
John_Mc
John, I have found that getting info on Fords and New Hollands can be challenging. From what I have been told......The 1620 is the hydro version of the 1720. I was told that everything else is the same. Assuming that this is true (until informed otherwise), do you have any other specs? 3pt hitch, hyd flow, engine displacement, total weight. I am truly starved for information on this tractor. Any help is appreciated.
Jerry
   / Ford 1620 Deal or No-Deal?? #5
Jerry,
I copied this from the Tractor data website.
<A target="_blank" HREF=http://www.tractordata.com/>http://www.tractordata.com/</A>
Ford-New Holland
1620
Manufactured: 1992 - 1997
Cost: $17,000 (1997)
Horsepower:
Engine: 27
PTO: 22
Engine:
Fuel: diesel
Cylinders: 3
Displacement: 81.1
Manufacturer: Shibaura
Transmission:
Forward: infinite
Reverse: infinite
Capacity (Gal):
Fuel: 7.1
3-Point:
Category: I
Power Take Off (PTO):
Type: live
Speed (RPM): 540
Tires:
Front: 5.00-15
Rear: 9.5-24
Weight: 2,250 lbs
Serial Numbers:
Spencer, the TC30 implement flow rate is 6 gpm and 3.5 gpm for steering. I was thinking that maybe the 1620 has more flow than this??? So, whats a good price on a TC30?? I was quoted $16,300 with R4's, hydro, and loader.
Jerry
   / Ford 1620 Deal or No-Deal?? #7
This comes from the All Makes Tractor tips website
http://www.tractortips.com/make_model/specsdisplay.asp
Tractor Specification
Make: FORD Model: 1620
FWD/REV Standard: Hitch Lift: 1637
FWD/REV Optional: Hydraulics-Type: OPEN
Years Made: 1992-1997 MFWD-STD/OPT: OPT HYD-CAP: 7.1
HP-PTO: 22 Tires_SD/OPT: 5.00-15 Tires-STD Front: 10.0
HP-Engine: 27 Tires-STD Rear: 9.5-24 HVD Std Outlets: OPT
HP-Drawbar: Wheelbase - Inch: 63.0 Cooling Capacity:
Engine-Make: SHIBAURA PTO Type: LIVE Fuel Tank Capacity: 7.1
Engine-Fuel: DIESEL PTO Speed: 540 Cab-Std A/C, ROPS:
Engine-CYL(s)-CID: 3/81.1 3PT Hitch CAT I: Yes Weight: 2233
Transmission-STD: HYDRO 3PT Hitch CAT II: No New Price: $16,701.00
Optional: 3PT Hitch CAT III: No
   / Ford 1620 Deal or No-Deal?? #8
1993 Ford 1620 ($7,500)
1300 hrs, w/loader, 60" bucket, 13.6 x 16 turf tires
KROMMINGA
MOTORS Phone
(319)465-5443
19415 Hwy. 151 South
Monticello, IA 52310
FAX
(319)465-4688
NEW HOLLAND
Open 7:30 until 5:00 Monday through Friday, Saturday until Noon
Email Address:
krommingamotors@n-connect.net
__________________________
DETAILS for TRACTORS from FORD
Model = 1620 4WD COMPACT
SPECIFICATIONS
Years Mfg: 1992-1996
Fuel: D
Engine Make: SHIBAURA 3-CYL
CID: 81.1
Engine HP: 22 PTO
27.3-E
Cab: ROPS
No.Speeds: HYDRO
Weight(Pounds): 2,352
List Price: $14,705
PRICING
Year Ad Price Est.Loan Value
1992 $8,529 $5,629
1993 $8,970 $5,920
1994 $9,411 $6,211
1995 $10,146 $6,696
1996 $10,441 $6,891
Wow, John Miller, your info (as usual) is a real show stopper. You must work for the government or something.
Seriously, thanks, I think I will be looking for a better deal. I know my dealer won't come down that low. I saw one of these sell on Ebay two weeks ago for $8,500. Seems like the $7,500 to $8,500 is the right price range.
Thanks to everyone who responded. You guys really came through on this one.
Jerry
   / Ford 1620 Deal or No-Deal?? #10
I had a deal on a 1993 Ford 1620, semi new turf tires, with 2,300 hrs, new FEL, 72" MMM for total price of $9,250, just to give you a comparison. Didn't buy it because the MMM did not leave any clearance at its highest position (less than 3"). Also thought it was a little big for my needs. The tractor was $6,500 and the FEL was $2,750.
2x 2008 Radiators for International Trucks (A46877)
2x 2008 Radiators...
Ryobi Compound Miter Saw (A44391)
Ryobi Compound...
2011 Dodge Ram 2500 Crew Cab Pickup Truck (A44572)
2011 Dodge Ram...
2015 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A44571)
2015 Crane Carrier...
New/Unused 20ft Bi-Parting Iron Gate (A44391)
New/Unused 20ft...
2014 Chrysler 200 Passenger Car, VIN # 1C3CCBCG7EN159508 (A44391)
2014 Chrysler 200...
