Marinemammal
- Joined
 - May 4, 2021
- Messages
 - 50
- Location
 - Oregon
- Tractor
 - Ford 1700, Massey Ferguson 175, Wood Mizer LT15
After several days of trying different plumbing arrangements, nothing seemed to work. I drained the oil and cleaned the screen, replaced the used (but clean-looking) oil and it worked fine--for about 20 minutes. This is confusing, because the screen looked clean (before cleaning it) as did the oil. Even after cleaning the screen, if I removed the banjo bolt at the screen, very little oil would run out--maybe a stream about 1/8 inch. After running for 20 minutes the hydraulics quit, and hardly any oil would run out with the banjo bolt removed. So I installed a 3/4 inch plastic threaded pipe in the banjo hole (it fits) and blew air back through the screen and everything worked again--for about 20 minutes. So I drilled a 3/8 inch hole in the end of the screen cylinder and everything works fine and it seems like it's going to stay that way. The loader is faster and better than ever.
I know this is not a good idea, but I didn't know what else to do. So my plan now is to get new oil, plug the drilled hole with a bolt and drill 1/16 inch holes in the end of the screen--36 of them if there's room. I would like to add an external oil filter on to the system, but don't know how to do it since all the external lines are subject to 2000 psi.
It's plumbed like this. Pump-----Loader-----Relief Valve (relieves to trans)-----Power Steering----Three-Point
As in my previously attached drawing...
