JC-jetro
Elite Member
I bought the IT FO-44 manual- 30.00 plus 5 shipping.
Any suggestions of things I could/should do while I have it split in half??
Thanks-
Nope, it seems you have all your ducks in a row. I had a nightmare scenario once. About 25 years ago I changed a clutch disk for a buddy in college just to earn a bit of cash money. I ended up buying a reman pressure plate and disk. Apparently the pressure plate was re-ground. Making a long story short, took every thing apart, put the reman stuff in, put things back, started the car and all looking and sounding good while gear in neutral. I clutched, first gear and no go
Compare pressure plate thickness for sure and make sure it is not free spinning after you install and torqued the pressure plate to flywheel.
Make sure to check the seals for oil leakage from transmission and also engine side. Guys reporting flywheel bolts to engine are torqued in excess of 250 lb-ft
JC,
