JC....I installed my "dirt cheap" pressure gauge and need to ask what to expect. In my feeble mind....I do not know where this gauge is in the hydraulic circuit, but I installed it in the same port as yours is.
When should I expect pressure....like under load only, or all the time, or will the pressure vary depending on the 3PH load? Mine has never gone above around 600 (spike only) when I take the empty lift up and stays down there pretty close to 100 or so when the lift is about half way and stabilized.
Hey old,
Glad you got our P gauge. For 1700 the rated pressure at 2500 rpm (gets pto rpm of 540) is 2133 psi or just say 2100 psi. Mine is just about 50 psi less of that and since I can lift my heaviest implement without any issues did not try to increase it.
-The pump flow is proportional to engine rpm and the pressure increase as rpm increases. The relief pressure valve maintain the max pressure by bypassing excess. If the pump is dead headed the pressure increase without stop till something breaks. Gear pump don't have the ability to dead head and spin for a short period like centrifugal pump.
-You should expect to read around 2000 psi under operating rpm with or without an implement. Depending on how tired your pump is you might have problems getting the pressure lifting a heavy equipment.
-with load or without load on the hitch as you raise the lift arm when it gets to final top position the relief mechanism should chatter and relive and that should be around 2133 psi give or take some.
-if relief pressure is let say 1800 psi then you can stiffen the spring in relief or adding shims to increase relief pressure, higher the relief and more you can pick up with your 3-point. You do not want to increase your relief to much higher pressure thinking your increasing your lift capacity. That might damage other components of your system including your pump. not a good thing.
-when the engine is off and you have something hanging from your 3 point then the pressure that you would read is the weight of your lift arm and implement that pushes or compresses the hyd oil in the cylinder. That is purely a function of the weight hanging and it can be anywhere as far as psi.
-with engine off as you lower the implement and you'll notice pressure dropping till you hit the ground and it read close to zero. If you keep the tractor under the sun the expansion of oil can increase the pressure with no load just due to expansion of the hys oil.
-where you have you gauge is downstream of relief and spool valve and just before the lift cylinder so it is representative of cylinder pressure.
I had a thread about it and add it below for your reading enjoyment
JC,
http://www.tractorbynet.com/forums/new-holland-owning-operating/130597-adjust-not-adjust.html
