JC-jetro
Elite Member
JC, My engine block heater came with the tractor when new so I assume it was factory installed and would be available from the NH Dealer as a parts order. Check to see if yours has the soft plug installed with the plug in reciever, if so all you would need is the cord. See attachments:
I have tested my glow plug problem and found the glow indicator is OK. Took the wires off and tested it for continuity and it was not broken. Reattached the wires and turned the switch and it worked. Problem may have been either a bad ground or could still be an ignition switch problem. I will watch it to see if it is still intermittant on/off. Ray
Ray,
Thanks for the pic. Mine does not have it and as you said it must be a factory option or may be after market add on. I don't reckon I need it too bad. you probably cleaned the contact enough for it to go. All the rusty and other wise poor connection add a cumulative current loss and by the time it gets to glow plug may not be enough. the god part about it is simple enough to get around and do it with a simple fix.
JC,
