Ford 1710 hydraulic pump.
   / Ford 1710 hydraulic pump. #1
Burbank_Barry
petaluma,ca
ford 1710
What is the best way to determine if a hydraulic pump has gone bad on a Ford 1710 tractor.
If the tractor has sat for 1 hour the bucket will work fine for a few minutes then cease to work. If I repeat that previous procedure the same thing happens again. I also noticed the steering is affected which is assisted by the hydraulic pump.
Thanks
My hydraulic fluid level is good. I need to figure out the location of this screen and check it out.
   / Ford 1710 hydraulic pump. #5
Sounds like your pump might be losing prime or sucking in air. If it works for a bit then quits, check the hydraulic fluid level first. Make sure it’s not low or foamy. Also take a look at the suction line and fittings for any cracks or loose spots. Sometimes it’s just pulling air instead of fluid.
If that all looks fine, try changing the hydraulic filter. A clogged one can make it act up like that. Only if none of that helps would I start thinking the pump itself’s going bad.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
Komatsu Midi Excavator (A55851)
Komatsu Midi...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
