ford 1910, can't find parts
   / ford 1910, can't find parts
You were right, I only pulled one sleeve last night but it came out easy. I was surprised by the gush of antifreeze that came out all over the floor even though I drained the dam thing. Guess what I used to hold the top plate and nut for pulling? A 12 inch piece of 4 inch schedule 40 pipe. The diameter was perfect, it was ridged enough to support the load and so easy to work with. I cut the center section out of an old mower blade that already had a hole in the center, I welded a thick flat washer over the hole for the big nut to spin on, welded two stops to the plate so it would stay centered on the pipe and it worked perfect. I got carried away making the unit that pulls the sleeve out, it looks high tec and works so nice.
It's winter, time to finish the rebuild on my Ford 1910.
Found a second hand injector pump from Long Lane tractor, off a running tractor, looks new and or rebuilt not that long ago, $200.00. I am done with my sleeve puller if anyone wants to borrow it. Engine is done and looking like new. BUT, not sure about the injectors. I can not afford new ones, out of work now. How hard is it to take them apart and clean them? Who can test them? No one around me does that, they all say just buy new ones.
I am also looking for a used right side rear fender, mine is too beat up to pound out easily before painting.
Grefg
Hi, Can you find me drive shaft seals for my 1910?
   / ford 1910, can't find parts #55
Sorry to necro but, we're you ever able to find pre-cups or other head parts? Or engines that have parts that interchange?
From what I can tell the parts for the 1910 are made for it and it alone is this the same you found?
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
2014 Ford F150 XL Pickup Truck (A53117)
2014 Ford F150 XL...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
7021 (A50322)
7021 (A50322)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
