Ford 1910 Fuel in the Oil and Puking Out Breather Tube
   / Ford 1910 Fuel in the Oil and Puking Out Breather Tube
I believe there are o-rings that break down. Check with an injector shop. They may be able to cross match the parts. I had this problem in my duramax. I haven't noticed it in my ford 1210 yet.
Thanks again.
   / Ford 1910 Fuel in the Oil and Puking Out Breather Tube #32
Keep in mind, when an injector is rebuilt, ie: replacing the nozzles, the assembly MUST be pressure tested and MUST be adjusted to the correct opening pressure. Also, a CLEAN work area is a MUST also.
Find a reputable diesel shop do this work.
   / Ford 1910 Fuel in the Oil and Puking Out Breather Tube #33
My tractor sits a lot but is in great shape. It's a 1984 Shibaura (Ford) model 1910 3 cyl diesel.
It starts but is reluctant to do so. Takes about 20-30 seconds of cranking (after 10 seconds of glow plug warm-up) when cold to get it to catch. The other day, while I was using it and the engine was up to temp, I noticed it puking "watery" oil out of the breather tube that goes to the head cover. Checked the dipstick and it was way over full of the watery oil.
First, what's likely wrong? I won't start it again until I change the oil, but I need to find the root cause.
Second, what's a good source for parts like injectors? I see lots of 20-series parts online, but not much out there for the 10-series.
Thanks in advance.
Jim
Would have to debate the comment that it is in great shape. Not!
Hope you find the problem.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
Pallet of Lights (A53117)
Pallet of Lights...
