Ford 3000 3-point not working
   / Ford 3000 3-point not working #21
Soundguy, After giving it some thought and considering my best options as I know them, I think I will add a fitting and a extra on/off valve and tee off present
factory set-up so that I can by-pass the original routing with the mechanical pump and have the option to run direct gravity feed with a 2-4 psi electric fuel pump
on the carburator feed line if needed and still be able to use the long about routing including the mechanical pump if this dosen't work out.
I think it will be fun to see if this works and if the results are as I hope/or not I will certainly give you that feedback.
Thanks Again....Joe Hoag
   / Ford 3000 3-point not working #22
now that I think about it, we had a ford industrial engine on a wood chipper here a few weeks back ( just sld it actually ).. I converted that one to a 2-4 psi electric pump.. key on.. etc.. and just made up my own fuel line and used an inline filter.. vs the old can / canister fuel fitler that had been on it. mechanical pump on that one was deffinately kaput...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
1840 (A51248)
1840 (A51248)
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
