Ford 3000 3-point not working
   / Ford 3000 3-point not working #21
Soundguy, After giving it some thought and considering my best options as I know them, I think I will add a fitting and a extra on/off valve and tee off present
factory set-up so that I can by-pass the original routing with the mechanical pump and have the option to run direct gravity feed with a 2-4 psi electric fuel pump
on the carburator feed line if needed and still be able to use the long about routing including the mechanical pump if this dosen't work out.
I think it will be fun to see if this works and if the results are as I hope/or not I will certainly give you that feedback.
Thanks Again....Joe Hoag
   / Ford 3000 3-point not working #22
now that I think about it, we had a ford industrial engine on a wood chipper here a few weeks back ( just sld it actually ).. I converted that one to a 2-4 psi electric pump.. key on.. etc.. and just made up my own fuel line and used an inline filter.. vs the old can / canister fuel fitler that had been on it. mechanical pump on that one was deffinately kaput...
2363 (A60432)
2363 (A60432)
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A61306)
Greenworks...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
