Ford 3000 - Blueish hue smoke story / question
   / Ford 3000 - Blueish hue smoke story / question #31
   / Ford 3000 - Blueish hue smoke story / question #32
Re-read post #21.
It says that the coolant level has NOT changed. It was a short post and easy to miss.
jb
You are right. it's a short post and easy to missread.. It's a QUESTION he's asking in post #21.. he starts the post with 'IF' as in.. 'if' the level doesn't change, then ...yada..yada.yada...
Unless the original poster is going to issue a clarification.. i believe post #19 is the last one we have to go on re: the coolant.. as it is a statement.. and #21 is merely asking a question.
soundguy
well that morning it was going like a bug fogger after having idled it for some time under no load. since parked it. started it back drove to brothers and it cleared up but was faintly starting again when i got over there and sat for a bit. i then let it idle real low for 30 seconds and throttled it to high and black and grey rolled out continuing with white and it started dimishing more and more as it ran full. it sure didnt do like it did the day i had it idling for some time. 20 mins that day maybe i had it idling low rpm, and it wouldnt clear up course i didnt run it hard that day either because i was worried i might mess something up. im much more at ease now with it. ill keep an eye on my lvls and go from there.
i was thinking last night how i bet ALOT of people run into this that dont know much about tractors, take it to a shop, and get told ENGINE REBUILD TIME, when that isnt even the case.
i meant to say does not appear to have moved. and if it was coolant id be seeing it at all times i would think and i dont see it when its under a load, not parked. i can even let it idle at full throttle and it seems to be fine, its just when i let it idle real low, unworked that is. key is dont run it if youre not working it or youre not driving it, i guess, lol.
   / Ford 3000 - Blueish hue smoke story / question #36
thartweger:
Seriously man, you're way overthinking this. Just do like John Bud and myself have said - go use your tractor. Stop worrying. It's older, it will smoke at idle/no load. The smoke clears when worked hard - all's fine, its just an older tractor. That tractor has hundreds of hours left in it. You will definitely know when something serious is wrong. If the the tractor sounds like something is wrong, then you've got another story. If you really don't like to look at the smoke, go finance a brand new tractor. You'll pay an awful lot of money to get what you've got in that old Ford 3000. Work it hard - it will thank you by clearing right up. Don't believe me, go down to a construction site and look at a Caterpillar with a couple of thousand hours on it when it starts up first thing in the morning - it'll do the same thing. I've got an awful lot of experience with all types of diesels, I'm not lying to you. I've even owned a Ford 5000 - did the same thing you describe here, and I never gave it a second thought. If this is for your business, don't burden yourself with expensive repairs for no reason other than to make yourself feel better. If you've got that kind of disposable income, but it towards a newer tractor.
well thats the point, i dont want to burden myself with expensive repairs. thats the reason i shut it down, and inquired as to what might be going on. if it something different then what weve talked about i willl let you guys know but i think weve hit the nail on the head. problem is i dont know when ill be using it again, but cant wait to put it to the test once again.
   / Ford 3000 - Blueish hue smoke story / question #38
Where are you located? Can you post some pictures? Also, if you don't mind me asking, how much do you have invested in this tractor?
Well if you dont consider gas and time and a couple other things, 3850.
i am located in st louis, mo area and i can get you some pictures sure give me a bit.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
1973 TANDEM AXLE DUMP TRUCK (A52576)
1973 TANDEM AXLE...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
